exim in CMD_SYSTEM_INFO
brewweb
exim built from ports on freebsd 8.2-RELEASE-p5, it works just fine
4774 ?? Ss 0:27.86 /usr/local/sbin/exim -bd -q30m (exim-4.77-1)
21296 ?? S 0:00.00 /usr/local/sbin/exim -bd -q30m (exim-4.77-1)
it has record in services.status
exim-4.77-1=ON
and I can see its pids as admin in CMD_SHOW_SERVICES, but as user in CMD_SYSTEM_INFO I see
Exim *** Stopped ***
Version info:
Compiled on FreeBSD 8.0 64-bit
Compile Date Feb 3 2012, 07:29:09
Server Version 1.40.3
Current Available Version 1.403000
Because it should be exim=ON that exim-4.77-1 is wrong
That might be a bug. I dont know how it could of changed into that. Try starting and stopping it from directadmin and see if it changes back to 4.77-1
Also check the /usr/local/directadmin/data/admin/services.status file to make sure the line says:
exim=ON
exim=ON
No, then i become as admin in CMD_SHOW_SERVICES
exim Process is stopped
with
exim-4.77-1=ON
I see that exim is running and all its pids
exim-4.77-1 exim-4.77-1 (pid 55667 55663 55302 55300 27156 27062 14586 14578 14312 77071 75048 78000 )
Anyway thank you.
If I'm not mistaken you should have /usr/local/etc/rc.d/exim-4.77-1 or /usr/local/etc/rc.d/exim-4.77-1.sh then. And it's process name should also be as exim-4.77-1 but not exim.
That's right. Looks like the problem of exim status in CMD_SYSTEM_INFO is somewhere else.
Why don't you rename it to exim simply?
I don't want:) It will be broken after next update of exim, almost all software on my server is built from ports of Freebsd. Its more easy to update and I have all dependencies in one place.
