Exim Problems (I think)
Have you made sure you have the latest exim.pl file?
I've explained where to get it in a previous post to this thread.
Martynas, you're very kind - and I mean it
it is 5 AM in the morning - 1.2K of garbage in the mailqueue - cleaning again
seems like nobody actually familiar with this thing.
Please send me your serer details if you want me to take a look at it :)
The error is fairly straight-forward; the option is unset.
While I'm emphatically NOT telling you to give access to your server to anyone (I will say that we trust Martynas implicitly but that doesn't mean you should), I will add that unless you give someone access you're on your own as to finding out why the option is unset.
Jeff, thanks for your reply, but I didn't understand the message at all, except
"the option is unset"
I'm very glad to know that, in fact - I feel releived already that "the option is unset"
Surely, there is a meaning behind "the option is unset", but until complete enlightment I cannot grasp it. Please explian :-)
P.S. The point well taken.
And I have no idea why the option is unset unless I look at your server.
And I may be more expensive than Martynas ;).
Jeff, I just love the way you post:
and previously:
Love it!
We all know what the error is saying and what it means. We just don't know why it's saying it without looking at the server as the steps we asked you to follow should've fixed it. Jeff wasn't being a hypocrite if that's what you were trying to imply. :)
thanks for your swift reply, Dravu
It is great that I already was "trying to imply" something that doesn't exist in my dictionary- probably it is some new title or rank - sort of a "guru" ?
seriously, how about the plain vanilla english?
Last post - you made a statement - I replied and ask some help, you didn't reply to it, instead - I got this:
Because Jeff, Martynas, and I have already said pretty much all we can from the knowledge that we know of the issue. I asked you before to see if a certain snippet of coding was in your configuration file. It was, according to you. With that in there, you shouldn't have been getting that error. So without someone going in and looking around or trying various things that might or might not be related (such as "./build all" again and checking for errors), there's little to nothing for us to advice with certainty (as you don't seem to like to try things if you're not sure it'll work).
I personally think you should take Martynas up on his off of a free look at the server. He's helped with my server once in the past with an error I wouldn't have ever thought of, that kept me from being able to upgrade PHP. Just set SSH to grant root login, change the password, give him access, and then change everything back when he's done.
And on a last note, a "hypocrite" as defined by Wikipedia:
Hypocrisy (or the state of being a hypocrite) is the act of preaching a certain belief or way of life, but not, in fact, holding these same virtues oneself. For example, an adult telling children not to smoke cigarettes, even though the adult smokes.
The way I used it was rather light and so I probably should've used a different word for it. But basically, I was saying that Jeff wasn't saying something to you and then later saying the opposite. You just misunderstood.
Dear Dravu,
First - thanks for your reply. It is big and very clear.
Unfortunately - I can't use mr Martynas service, and I do beleive that he is good and very nice gentleman, but...
As for the term you've point to Wiki -- well, I'm at the forum asking for advice, not to extend my dictionary with pop words.
Thanks anyway - hopefully I might solve that issue myself
This is a fix for the problem:
patch -p0 < /usr/local/directadmin/custombuild/exim.conf.dovecot.patch
