Forbidden error help me
Panel Picture
Mon Dec 21 17:19:01.651355 2020] [ssl:warn] [pid 1270:tid 140696187242624] AH01909: www.demo.hostingsatisi.com:443:0 server certificate does NOT include an ID which matches the server name
[Mon Dec 21 17:19:20.367216 2020] [autoindex:error] [pid 1178:tid 140695296833280] [client 95.10.189.64:38676] AH01276: Cannot serve directory /home/hostingsatisi/domains/hostingsatisi.com/: No matching DirectoryIndex (index.html,index.htm,index.shtml,index.php,index.phtml) found, and server-generated directory index forbidden by Options directive
[Mon Dec 21 17:24:24.340556 2020] [autoindex:error] [pid 1178:tid 140695296833280] [client 5.181.233.54:40621] AH01276: Cannot serve directory /home/hostingsatisi/domains/hostingsatisi.com/: No matching DirectoryIndex (index.html,index.htm,index.shtml,index.php,index.phtml) found, and server-generated directory index forbidden by Options directive
You have a custom root directory. You have to put the index in whatever root directory you specified. But why did you change it? You are not telling us everything.
root directory I changed, there is nothing, it automatically hurts in that area
You should reset the root directory for the subdomains to the default.
