Duboux
- Apr 20, 2007
I made a php script that:
If and once Jeff is happy with this file, everyone using SpamBlocker can help him giving test results.
Next to that, it's easy to use for everyone that needs to have a look into those logs, for example when someone says he's been blocked.
It works with both pre-generated Shell commands (ready to copy/paste into shell) and works with file-upload, so you can upload parts of the logs.
For more info, read the header in the file itself
* I don't think you want to open a file bigger than 10mb in your browser...
- makes reading Reject-lines in parts* of Exim mainlog & rejectlog read easier
- helps with the testing of SpamBlocker results
