directadmin skin file are html files! How I can manage licence for these files!?Most of the people i think use WHMCS with the License Manager plugin.
Regards
I would like to manage licence like "Darwin skin", How I can do it?Hello,
Andrea is right here. The skins files have inclusions of PHP code which is encrypted in a separate set of classes or functions. Note, if you simply add a PHP code to check license then it might be not secure. You need to ship functionality in PHP code.
pm sent, no answer yet from developer!Feel free to ask the "Darwin skin" developers about it. Or probably other guys here know more about the "Darwin skin" and will share their ideas.
this is why I opened this topic! How I can manage licence for DA Skin if ioncube does not help!?Wait... WHMCS licencing addon supposes that you encode your PHP files with IonCube for example, of course if you don't afraid that your kin will be NULLed. If you encode templates, directadmin won't be able to read them, thus they will be ruined.
I have Darwin skin! but its files are open source and I couldn't find out how its developer manages its licence!Buy any paid skin or use a trial version where it's possible and see how they are done from inside.
I am going to do what Darwin did! Best protection is : Support and update!Why do you want to sell licenses?
As mentioned earlier, you can go at least three ways:
1. Trust your users and do not encode any file and sell the skin at a low price, so that it would be easier/safer to buy the skin from the trusted place/market/site.
2. Do not encode any file of a skin either, and write a script to autoupdate the skin, and on the server side you would check whether or not user has a valid license to download a skin. Darwin Skin seems to follow this way. Quick way to run skin.
3. Add in skin files PHP code which would include an encoded PHP script which would periodically connect to your server and verify license. License verification will slow down browsing DA in certain cases. And what if your server will be down? How much will an user allowed to use the skin without verification? And what your PHP code will do? It should add extra functionality...What if they remove the PHP script or replace it with an empty PHP file? If the only purpose of a PHP script to verify license your skin will be easily nulled. CyberAdmin skin seems to follow this way, they add extra functionality with custom PHP script and verify licenses with it.
