FastAttack
- Dec 27, 2004
duke28 said:hi
where is the crondjob hjas been added ??
or what i need to add to cronjob..
cronjob is automatically done for you.
I believe its in cron.daily folder
duke28 said:hi
perl installRDJ.pl --install --sa_restart="/etc/init.d/exim restart" --sa_dir=/etc/spamassassin
The mail command is the command that you use to send email from the command line.
A default (even minimal) CentOS command should have the mail command.
Try, logging in as shell as admin:
and
again as root:
(you do not type the $ or the #; they're just to show you're either root or not)
and see if you get something or an error. If you get an error you may not have a proper installation.
Either way, exit the program with control-C, and then do:
$ whereis mail
and post the results.
-bash-3.00# mail
-bash: mail: command not found
-bash-3.00# whereis mail
mail: /etc/mail
