With most forums, that is not the case.
I run or have run IPB, Xenforo, Vbulletin and phpBB forums, i've never seen code tags collapsing. Or I might misunderstand you.
I presume you mean collapsing in width? Might be some mod or adjustment if you have seen that somewhere.
With the current forum software, being Xenforo, you got 2 kinds of code tags. You have the normal code and the icode tags (or rather bbcodes).
This is an example of icode used:
[icode]This is some test in icode[/icode]
which results in:
Then you have the normal code tag, known on every forum software (maybe not the newest versions ipb anymore because they don't support bbcode anymore).
[code]This is some test in code[/code]
which results in
If i use a large code, with the normal code tag, it will be like this:
2021-11-14 05:18:27 1mm6yI-0002n8-6l <= [email protected] H=mail73.sea41.rsgsv.net [148.105.13.73] P=esmtps X=TLS1.2:ECDHE-RSA-AES128-GCM-SHA256:128 CV=no S=246027 DKIM=hbm-machines.com id=542b6f4eac84c4eb84aa4072a.5be836d6a6.20211114041556.88e430e2bd.1bfc17c5@mail73.sea41.rsgsv.net T="Spectaculair veel voordeel!" from <[email protected]> for [email protected]
Is that what you mean? Because I have not see this wrapped in any forum software.
However, if you use the quote tag instead of the code tag.....
[email protected]
then it's wrapping, maybe you mistaken the code tag for the quote tag?
If this is not what you mean, maybe you can clarify?
