Hi there everyone.
I have installed the letsencrypt module to create SSL Certificates for three subdomains:
mail.domain.com
smtp.domain.com
imap.domain.com
dovecot and exim are however, not using these letsencrypt certificates. Opening roundcube on either of these domains shows that the letsencrypt SSL Certificate is being used, but configuring my mail server using these domains in for example the outlook mail client produces an error that mentions that the server you're connecting to is using an untrusted certificate, which, when viewed, points to a self signed localhost certificate.
I checked in the dovecot mail.domain.com.conf config file aswell as the exim.cariables.conf and they seem to be pointing to the correct certificate file.
Does anyone here have had the same problem and is there a guide or manual that points me into the right direction on how to correctly configure this?
Thanks in advance.
mail.domain.com
smtp.domain.com
imap.domain.com
Thanks in advance.
