Majordomo problem
SeLLeRoNe
Super Moderator
A Coruña, Spain
: >>>> approve futuro unsubscribe expert01 EMAIL
: >>> Sorry, an error has occurred while processing your request
: >>> The caretaker of Majordomo ( majordomo-owner@DOMAIN ) has been
notified
: >>> of the problem.
one jof my customers had this problem while trying to unsubscrive from mailing list.
anyone can help?
thanks
The email address must be a complete email address with no additional punctuation, for example:
If that's not working and it's just for one email address, then just use the DirectAdmin interface to manually unsubscribe.
address@example.
Nice complete email address.
mmmh ok, so why when they try to unsubscrive without use directadmin they receive that email as a reply?
is my customer doing something wrong?
I don't know.
Perhaps you can learn Majordomo, ask on the Majordomo-users list? Or hire someone to log in and look?
I'd suggest that a root shell is going to be the place to look. I'm not sure what can be found; I used to use Majordomo heavily in a commercial enterprise, but it's been years, and even then i sometimes had to ask on the Majordomo-users list for help.
If I recall correctly, Majordomo is simply a collection of Perl scripts; you can add commands to print specific values to a log-file you create yourself.
I had the same problem. I think I found where is a problem.
In majordomo.log I have:
ABORT chown(1002, 1, "/etc/virtual/domain.com/majordomo/lists/test.new"): Operation not permitted
So I check and one file test.new have owner:group
-rw-rw-r-- 1 majordomo bin        0 2009-09-07 11:37 test.new
other files
-rw-rw---- 1 majordomo daemon  1357 2009-09-07 11:37 test.config
-rw-rw-r-- 1 majordomo daemon     0 2009-09-03 12:03 test-digest
drwxrwx--x 2 majordomo daemon  4096 2009-09-03 12:03 test-digest.archive
-rw-rw---- 1 majordomo daemon  1371 2009-09-07 11:37 test-digest.config
-rw-rw---- 1 majordomo daemon    25 2009-09-07 11:37 test-digest.info
-rw-rw---- 1 majordomo daemon    25 2009-09-07 11:37 test.info
So, I check and I changed group on file test.new from bin to daemon like others.
Then I send unsubscribe list. And works fine.
But whenever I want change settings in mailing list "test" then file test.new change group to "bin".
In /etc/virtual/majordomo/ files has owner:group - majordomo:bin
I changed it to majordomo:daemon and I think problem resolved.
