Mysql integration php problem
yes, copied the library, reinstalled php/mysql/apache and removed some customed http configuration (done from directadmin) that had suphp on and the php was installed as cli.
Regards
If you tried all the howtos and it is still not fixed please do the following ,
This may be due to 64 32 bit incompatibility .
- Install mysql-devel packages from yum , if you are using default mysql otherwise get the correct version of mysql-devel and mysql-server 64 bit version , then here is the trick
remove /usr/lib/mysql
make the link " ln -s /usr/lib64/mysql /usr/lib/mysql
now " ldconfig "
Then add the following flag in custom build conf --with-mysql=/usr
Build it
