- Feb 27, 2003
I've downgraded custombuild to 5.2.14 for now.
cd /usr/local/src/eaccelerator/eaccelerator-0.9.6.1
export PHP_PREFIX="/usr/local"
$PHP_PREFIX/bin/phpize
make clean
./configure --without-eaccelerator-use-inode --enable-eaccelerator=shared --with-php-config=$PHP_PREFIX/bin/php-config
make
make test
make install
./build php n
*** MD5 Checksum for php-5.2.15-mail-header.patch Failed. Redownloading...***
Note that it will be normal to see:Code:./build update ./build php nCode:*** MD5 Checksum for php-5.2.15-mail-header.patch Failed. Redownloading...***
gcc: /usr/lib/mysql/libmysqlclient_r.so: No such file or directory
ln -s /usr/lib/libmysqlclient_r.so /usr/lib/mysql/libmysqlclient_r.so
./build php n
Warning: file_exists(): open_basedir restriction in effect. File(/root/.pearrc) is not within the allowed path(s): (/home/admin/:/tmp:/usr/local/lib/php:/var/www/html/squirrelmail/:/var/www/html/squirrelmail/:/var/www/html/phpMyAdmin/:/var/www/html/webmail:/usr/local/directadmin/:/var/www/html/roundcube:/usr/local/directadmin/:/var/www/html/atmail:/usr/local/directadmin/:/var/www/html/atmail-1.03/) in phar://install-pear-nozlib.phar/PEAR/Config.php on line 621
[PEAR] Archive_Tar - already installed: 1.3.7
[PEAR] Console_Getopt - already installed: 1.2.3
[PEAR] Structures_Graph- already installed: 1.0.3
[PEAR] XML_Util - already installed: 1.2.1
Warning: file_exists(): open_basedir restriction in effect. File(/usr/local/bin) is not within the allowed path(s): (/home/admin/:/tmp:/usr/local/lib/php:/var/www/html/squirrelmail/:/var/www/html/squirrelmail/:/var/www/html/phpMyAdmin/:/var/www/html/webmail:/usr/local/directadmin/:/var/www/html/roundcube:/usr/local/directadmin/:/var/www/html/atmail:/usr/local/directadmin/:/var/www/html/atmail-1.03/) in phar://install-pear-nozlib.phar/PEAR/Installer.php on line 546
Warning: file_exists(): open_basedir restriction in effect. File(/usr/local/bin) is not within the allowed path(s): (/home/admin/:/tmp:/usr/local/lib/php:/var/www/html/squirrelmail/:/var/www/html/squirrelmail/:/var/www/html/phpMyAdmin/:/var/www/html/webmail:/usr/local/directadmin/:/var/www/html/roundcube:/usr/local/directadmin/:/var/www/html/atmail:/usr/local/directadmin/:/var/www/html/atmail-1.03/) in phar://install-pear-nozlib.phar/System.php on line 265
Warning: file_exists(): open_basedir restriction in effect. File(/usr/local) is not within the allowed path(s): (/home/admin/:/tmp:/usr/local/lib/php:/var/www/html/squirrelmail/:/var/www/html/squirrelmail/:/var/www/html/phpMyAdmin/:/var/www/html/webmail:/usr/local/directadmin/:/var/www/html/roundcube:/usr/local/directadmin/:/var/www/html/atmail:/usr/local/directadmin/:/var/www/html/atmail-1.03/) in phar://install-pear-nozlib.phar/System.php on line 265
Warning: file_exists(): open_basedir restriction in effect. File(/usr) is not within the allowed path(s): (/home/admin/:/tmp:/usr/local/lib/php:/var/www/html/squirrelmail/:/var/www/html/squirrelmail/:/var/www/html/phpMyAdmin/:/var/www/html/webmail:/usr/local/directadmin/:/var/www/html/roundcube:/usr/local/directadmin/:/var/www/html/atmail:/usr/local/directadmin/:/var/www/html/atmail-1.03/) in phar://install-pear-nozlib.phar/System.php on line 265
Warning: file_exists(): open_basedir restriction in effect. File(/) is not within the allowed path(s): (/home/admin/:/tmp:/usr/local/lib/php:/var/www/html/squirrelmail/:/var/www/html/squirrelmail/:/var/www/html/phpMyAdmin/:/var/www/html/webmail:/usr/local/directadmin/:/var/www/html/roundcube:/usr/local/directadmin/:/var/www/html/atmail:/usr/local/directadmin/:/var/www/html/atmail-1.03/) in phar://install-pear-nozlib.phar/System.php on line 265
Warning: is_writeable(): open_basedir restriction in effect. File(/) is not within the allowed path(s): (/home/admin/:/tmp:/usr/local/lib/php:/var/www/html/squirrelmail/:/var/www/html/squirrelmail/:/var/www/html/phpMyAdmin/:/var/www/html/webmail:/usr/local/directadmin/:/var/www/html/roundcube:/usr/local/directadmin/:/var/www/html/atmail:/usr/local/directadmin/:/var/www/html/atmail-1.03/) in phar://install-pear-nozlib.phar/System.php on line 272
Warning: file_exists(): open_basedir restriction in effect. File(/usr/local/bin/pear.bak) is not within the allowed path(s): (/home/admin/:/tmp:/usr/local/lib/php:/var/www/html/squirrelmail/:/var/www/html/squirrelmail/:/var/www/html/phpMyAdmin/:/var/www/html/webmail:/usr/local/directadmin/:/var/www/html/roundcube:/usr/local/directadmin/:/var/www/html/atmail:/usr/local/directadmin/:/var/www/html/atmail-1.03/) in phar://install-pear-nozlib.phar/PEAR/Installer.php on line 956
Warning: file_exists(): open_basedir restriction in effect. File(/usr/local/bin/peardev.bak) is not within the allowed path(s): (/home/admin/:/tmp:/usr/local/lib/php:/var/www/html/squirrelmail/:/var/www/html/squirrelmail/:/var/www/html/phpMyAdmin/:/var/www/html/webmail:/usr/local/directadmin/:/var/www/html/roundcube:/usr/local/directadmin/:/var/www/html/atmail:/usr/local/directadmin/:/var/www/html/atmail-1.03/) in phar://install-pear-nozlib.phar/PEAR/Installer.php on line 956
Warning: file_exists(): open_basedir restriction in effect. File(/usr/local/bin/pecl.bak) is not within the allowed path(s): (/home/admin/:/tmp:/usr/local/lib/php:/var/www/html/squirrelmail/:/var/www/html/squirrelmail/:/var/www/html/phpMyAdmin/:/var/www/html/webmail:/usr/local/directadmin/:/var/www/html/roundcube:/usr/local/directadmin/:/var/www/html/atmail:/usr/local/directadmin/:/var/www/html/atmail-1.03/) in phar://install-pear-nozlib.phar/PEAR/Installer.php on line 956
Do I need to do that command or don't I?libtool: install: warning: remember to run `libtool --finish /usr/local/directadmin/custombuild/php-5.2.15/libs'
