kevinbentlage
- Jul 15, 2013
Hi There,
I've just setup a fresh DirectAdmin server, based on Debian 11 (x64), and did some default config on on it.
I'am having issue with PhpMyAdmin and MySQL client, it will not login to any database.
I already did some research, and it has to do something with the "Host" PhpMyAdmin users to reach MySQL. By default it's configured to 'localhost' in the config.inc.php:
I did all my tests with the default "da_admin" user.
My /etc/my.cnf config:
Also on the CLI it does not work:
My /etc/hosts does seem right:
Telnet works on both hosts:
Netstat:
MySQL user:
I've also tested to switch skip_name_resolve on or off, but this does not make a difference!
What do i miss here?
When i change this to:$cfg['Servers'][$i]['host'] = 'localhost';
It works! But when i'll rebuild (or update) PHPMyAdmin, this value will be restored to the default (localhost).$cfg['Servers'][$i]['host'] = '127.0.0.1';
(Yes, we're using /data instead of /var/lib/mysql)[client-server]
[mysqld]
datadir = /data/mysql
socket = /data/mysql/mysql.sock
[client]
[server]
port = 3306
character-set-server = utf8
thread_concurrency = 8
innodb_thread_concurrency = 8
local-infile = 0
max_allowed_packet = 1G
skip_name_resolve = 1
wait_timeout = 28800
interactive_timeout = 28800
key_buffer_size = 128M
sort_buffer_size = 1M
#join_buffer_size = 4M
read_buffer_size = 1M
read_rnd_buffer_size = 2M
query_cache_type = 0
query_cache_size = 1024M
query_cache_limit = 8M
thread_cache_size = 8
tmp_table_size = 1G
max_heap_table_size = 256M
table_open_cache = 4000
innodb_lock_wait_timeout = 100
innodb_buffer_pool_size = 256M
innodb_buffer_pool_instances = 4
innodb_log_file_size = 256M
innodb_file_per_table = 1
innodb_log_buffer_size = 4M
innodb_file_format = Barracuda
log_error = /var/log/mysql/error.log
But works with 127.0.0.1[root@xxx01 phpMyAdmin]$ mysql -h localhost -u da_admin -p
Enter password:
ERROR 2002 (HY000): Can't connect to local server through socket '/tmp/mysql.sock' (2)
[root@xxx01 phpMyAdmin]$ mysql -h 127.0.0.1 -u da_admin -p
Enter password:
Welcome to the MariaDB monitor. Commands end with ; or \g.
Your MariaDB connection id is 212
Server version: 10.6.7-MariaDB MariaDB Server
Copyright (c) 2000, 2018, Oracle, MariaDB Corporation Ab and others.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
[root@xxx01 phpMyAdmin]$ cat /etc/hosts
# Do not remove the following line, or various programs
# that require network functionality will fail.
127.0.0.1 localhost
::1 localhost ip6-localhost ip6-loopback
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
1.2.3.4 xxx01.myhost.com xxx01
[root@xxx01 phpMyAdmin]$ telnet 127.0.0.1 3306
Trying 127.0.0.1...
Connected to 127.0.0.1.
Escape character is '^]'.
X
5.5.5-10.6.7-MariaDB2b"}sHN.;�{}#0g[sOromysql_native_password^CConnection closed by foreign host.
[root@xxx01 phpMyAdmin]$ telnet localhost 3306
Trying ::1...
Connected to localhost.
X
5.5.5-10.6.7-MariaDB3I1T8V-y?�k!]2!L=-f?Ctmysql_native_password^CConnection closed by foreign host.
Netstat:
[root@xxx01 phpMyAdmin]$ netstat -tnlp | grep 3306
tcp 0 0 0.0.0.0:3306 0.0.0.0:* LISTEN 693561/mariadbd
tcp6 0 0 :::3306 :::* LISTEN 693561/mariadbd
MySQL user:
MariaDB [mysql]> select Host, User from user WHERE user = 'da_admin';
| Host | User |
| localhost | da_admin |
1 row in set (0.001 sec)
