Prestashop module permission
diamondgate.ets
hi, anyone can help?
I install a Prestashop mega menu module from their marketplace
The installation went smooth but when I come to the module backend it show error: "Blog folder requires CMOD 777"
Can I change the cmod with directadmin and how?
vlijmenlive
Belgium
You can do this with the file manager build into DA. Just select the desired folder and set the permission to 777.
But please Google a bit around why using 777 is not really safe and don't do it unless it's really necessary.
diamondgate.ets
You're the man! the problem is solved now. Thanks so much!
