Problem POP3 not works
Nova Web LTD
Good morning,
these days I have installed on a VPS DA, everything works but the mail does not want to know.
The situation is very strange, and I don't know how to proceed.
ssl creation:
openssl req -new -newkey rsa: 2048 -nodes -keyout server.key -out server.csr
imap works and I send mail with SSL automatically, perfect. example
imap.server.com 993 SSL
mx.server.com 465 SSL
Pop3 not function does not accept the settings and is unable to send mail.
pop.server.com 995 SSL
by mistake and does not want to know
if i use this setting same error
pop.server.com 110 STARTTLS
Failed to authenticate on the server, the configuration, username and password may be incorrect
Some ideas please
- Does it work in RoundCube?
- Does it work from another device, mail program?
We use
- IMAP 143 with SSL/TLS
- SMTP 587 with SSL/TLS
- POP3 110 with SSL/TLS
Solved and discovered the problem.
I had written badly in the dovecot conf /ssl.conf file
Badly read the certificate ..
I have no words. Sorry
Can you please explain what exactly was the issue?
What was written badly in dovecot conf /ssl.conf file ?
of course,
I have encountered two problems, given that I use a multi certificate for centralized mail management.
when you receive a certificate you cannot rename it creates problems.
You must always use cat mx.mydomain.com.key > server.key
Using a centralized certifcate it works for all associated ip.
so in /etc/dovecot/conf/ssl.conf paste path:
ssl_cert = </etc/dovecot/xxx/server.crt
ssl_key = </etc/dovecot/xxx/server.key
ssl_dh = </etc/dovecot/dh.pem
ssl_min_protocol = TLSv1
ssl_cipher_list = ALL:! ADH: RC4 + RSA: + HIGH: + MEDIUM: -LOW: -SSLv2: -EXP
Second problem:
I had gone the wrong way of exim
Same for exim but differently:
openssl_options = + no_sslv2 + no_sslv3
tls_require_ciphers = ALL:! ADH: RC4 + RSA: + HIGH: + MEDIUM: -LOW: -SSLv2: -EXP
tls_certificate = /etc/dovecot/xxx/server.crt
tls_privatekey = /etc/dovecot/xxx/server.key
I hope it helps
