Problem with backup
yatoula
France (Metz)
My client is trying to make a backup and the system announces an error :
Error Compressing the backup file backup-Feb-2-2010-2.tar.gz: / bin / tar: domains / mccreation.ch / log: the open function failed: Permission not granted
/ bin / tar: Errors caused the program to stop
The folders "logs" is in chmod 755 and the files in is index.html in 755 ??
There's probably a permission error somehwere. Or someone has run chattr -i on something.
I can't think of any other reason.
That's as simple as I can get in English; try google translate on it to see if that helps.
chattr -i
is a command followed by a command option. Running it on a file will make it so nothing (not even root) can change it.
