Problem with DA and SSL
Mr. Jinx
I just ordered an SSL certificate for use with DA (admin interface).
However I just discovered DA doesn't like DES3 encrypted .key file :(
When I start DA it just stops telling the .key file is not correct.
I used this to create the key:
openssl genrsa -des3 -out domainname.key 1024
It now looks likes this:
-----BEGIN RSA PRIVATE KEY-----
Proc-Type: 4,ENCRYPTED
DEK-Info: DES-EDE3-CBC,84F8176D35A15AEE
FoE09JkTso38yqqkGfZvsRkltlBnJ484s0Rck2+G7xUZXN5hEvUMDvciMiRcOQm4
LIGxa5i.................etc
Is there a way to decrypt this file? (yes I know the passphase :))
Actually, you don't want to "decrypt" the private key, you want to convert it to a different format ;) Try this command:
openssl rsa -in domainname.key
or google for something like "how to convert private key to RSA format" for more info.
This is how I install ssl for server:
Make key
cd /etc/httpd/conf/ssl.key/
create CSR
openssl genrsa -out server.key 1024
openssl req -new -key server.key -out server.csr
Copy CSR
pico server.csr
Add CRT
pico -w /etc/httpd/conf/ssl.crt/server.crt
Check for port 443
### DirectAdmin on SLL
pico -w /usr/local/directadmin/conf/directadmin.conf
Change ds ssl to 1
Change ssl location to:
cacert=/etc/httpd/conf/ssl.crt/server.crt
cakey=/etc/httpd/conf/ssl.key/server.key
