dunowat2do
- Feb 23, 2006
I'm currently using DA as a DNS server for one of my domains that reside on a separate machine.
One of the problems I'm having is that the domain does not seem to be resolving correctly. I don't believe I have anything incorrect in my named.conf or my /var/named/domain.db file.
I'm a little lost that when I try to do a domain lookup it goes to the nameserver, but DA does not recognize it as an existing domain. All the records are in DA and i've checked /var/log/messages and it does load... I'm hoping that I can find some help with this, because it is baffling.
IP's for the name servers have been assigned and it worked briefly, then stopped for no apparent reason...
Any help is appreciated... Thank you...
