Problem with domain pointer
Are you writing about a DNS issue? domain doesn't show up in browser? Or are you writing about an error with the pointer itself showing up in your DirectAdmin login?
If the former, that's not related to anything DirectAdmin staff is working on; you need to check to see if your browser is restarting after you load a pointer, and if not, why not.
I wrote about both. DNS issue and invisible pointer in DA from level administrator on user list. If i want to see pointer on user list, must go to edit account and save without any changes. After this pointer in visible on user list. Second, domain pointer is no working after 72 hour from setup. If i want to see it in browser must manulally restart bind by ssh.
After, you add a pointer, check if file /usr/local/directadmin/data/task.queue exists, and with what content? And check with logs:
/var/log/directadmin/errortaskq.log
/var/log/directadmin/system.log
is there any line with information about restarting of named/bind
Hello.
After add pointer in logs are:
2011:04:01-10:03:01: httpd reloaded
2011:04:01-10:03:01: named reloaded
I've checked
File in: /usr/local/directadmin/data/task.queue
I don't see it. File no exist!
What that mean?
Thank You for help me.
That file if empty doesnt exist, if doesnt exist there should be 2 reason:
1 - task has not been added on submit
2 - task has alrady been processed
Regards
Regards
Hello, could You look at printscreen? Just added pointer to domain okoniewski.com.pl It dosen't exist on user list and can't find file:
When i login as user, i see this pointer on his account, as administrator no on user list.
Please help me understand this it's right?
http://dnssy.com/report.php?q=okoniewski.nexim.net.pl
as far as i read there is a bug on creating pointer, the pointer is created but not show in list, and it appear after nightly tally in cron from directadmin
the task.queue is craeted in the same moment as pointer is added and the cron fro that task is everyminute, so, should be that the file doesnt exist cause has already been processed.
Otherwise, can be missing in the same moment cause for some reason isnt created and so the error log should say something about that.
DirectAdmin staff sayd that the fix for pointer not showd in list will be fixed in next release.
But, this should cause problem on your dns, should just be a "not showd in list" problem apparently not related with dns
Checking the dns with dig seems that the A record is not created...
so, im trying to understand:
okoniewski.nexim.net.pl -> where is pointing?
do you own nexim.net.pl domain?
If okoniewski.nexim.net.pl is pointing to another domain you MUST (directadmin doesnt create the A record for a subdomain) create a A record into nexim.net.pl dns administration, if not, will never resolve i suppose.
Regards
Regards
Yes, okoniewski.nexim.net.pl i pointing to my own domain nexim.net.pl on his account.
Domain nexim.net.pl is my own domain, i've make pointer on his account:
okiniewski.nexim.net.pl
Please look at printscreen.
THX.
