make[1]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18'
Make complete
Removing all apache related rpms...
All apache related rpms have been removed.
Installing Apache...
Making install in srclib
make[1]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/srclib'
Making install in apr
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/srclib/apr'
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/srclib/apr'
make[3]: Nothing to be done for `local-all'.
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/srclib/apr'
/usr/local/directadmin/custombuild/httpd-2.4.18/srclib/apr/build/mkdir.sh /usr/lib/apache /usr/bin /var/www/build \
/usr/lib/apache/pkgconfig /usr/include/apache
/usr/bin/install -c -m 644 /usr/local/directadmin/custombuild/httpd-2.4.18/srclib/apr/include/apr.h /usr/include/apache
for f in /usr/local/directadmin/custombuild/httpd-2.4.18/srclib/apr/include/apr_*.h; do \
/usr/bin/install -c -m 644 ${f} /usr/include/apache; \
done
/bin/sh /usr/local/directadmin/custombuild/httpd-2.4.18/srclib/apr/libtool --mode=install /usr/bin/install -c -m 755 libapr-1.la /usr/lib/apach e
libtool: install: /usr/bin/install -c -m 755 .libs/libapr-1.so.0.5.2 /usr/lib/apache/libapr-1.so.0.5.2
libtool: install: (cd /usr/lib/apache && { ln -s -f libapr-1.so.0.5.2 libapr-1.so.0 || { rm -f libapr-1.so.0 && ln -s libapr-1.so.0.5.2 libapr- 1.so.0; }; })
libtool: install: (cd /usr/lib/apache && { ln -s -f libapr-1.so.0.5.2 libapr-1.so || { rm -f libapr-1.so && ln -s libapr-1.so.0.5.2 libapr-1.so ; }; })
libtool: install: /usr/bin/install -c -m 755 .libs/libapr-1.lai /usr/lib/apache/libapr-1.la
libtool: install: /usr/bin/install -c -m 755 .libs/libapr-1.a /usr/lib/apache/libapr-1.a
libtool: install: chmod 644 /usr/lib/apache/libapr-1.a
libtool: install: ranlib /usr/lib/apache/libapr-1.a
libtool: finish: PATH="/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/root/bin:/sbin" ldconfig -n /usr/lib/apache
Libraries have been installed in:
/usr/lib/apache
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the `-LLIBDIR'
flag during linking and do at least one of the following:
- add LIBDIR to the `LD_LIBRARY_PATH' environment variable
during execution
- add LIBDIR to the `LD_RUN_PATH' environment variable
during linking
- use the `-Wl,-rpath -Wl,LIBDIR' linker flag
- have your system administrator add LIBDIR to `/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
/usr/bin/install -c -m 644 apr.exp /usr/lib/apache/apr.exp
/usr/bin/install -c -m 644 apr.pc /usr/lib/apache/pkgconfig/apr-1.pc
for f in libtool shlibtool; do \
if test -f ${f}; then /usr/bin/install -c -m 755 ${f} /var/www/build; fi; \
done
/usr/bin/install -c -m 755 /usr/local/directadmin/custombuild/httpd-2.4.18/srclib/apr/build/mkdir.sh /var/www/build
for f in make_exports.awk make_var_export.awk; do \
/usr/bin/install -c -m 644 /usr/local/directadmin/custombuild/httpd-2.4.18/srclib/apr/build/${f} /var/www/build; \
done
/usr/bin/install -c -m 644 build/apr_rules.out /var/www/build/apr_rules.mk
/usr/bin/install -c -m 755 apr-config.out /usr/bin/apr-1-config
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/srclib/apr'
Making install in apr-util
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/srclib/apr-util'
Making all in xml/expat
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/srclib/apr-util/xml/expat'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/srclib/apr-util/xml/expat'
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/srclib/apr-util'
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/srclib/apr-util'
/usr/local/directadmin/custombuild/httpd-2.4.18/srclib/apr/build/mkdir.sh /usr/include/apache /usr/lib/apache/pkgconfig \
for f in /usr/local/directadmin/custombuild/httpd-2.4.18/srclib/apr-util/include/*.h /usr/local/directadmin/custombuild/httpd-2.4.18/srclib/apr -util/include/*.h; do \
done
/usr/bin/install -c -m 644 apr-util.pc /usr/lib/apache/pkgconfig/apr-util-1.pc
list='xml/expat'; for i in $list; do \
( cd $i ; make DESTDIR= install ); \
done
/bin/sh ./conftools/mkinstalldirs /usr/lib/apache /usr/include/apache
/bin/sh ./libtool --mode=install /usr/bin/install -c libexpat.la /usr/lib/apache/libexpat.la
libtool: install: /usr/bin/install -c .libs/libexpat.so.0.5.0 /usr/lib/apache/libexpat.so.0.5.0
libtool: install: (cd /usr/lib/apache && { ln -s -f libexpat.so.0.5.0 libexpat.so.0 || { rm -f libexpat.so.0 && ln -s libexpat.so.0.5.0 libexpa t.so.0; }; })
libtool: install: (cd /usr/lib/apache && { ln -s -f libexpat.so.0.5.0 libexpat.so || { rm -f libexpat.so && ln -s libexpat.so.0.5.0 libexpat.so ; }; })
libtool: install: /usr/bin/install -c .libs/libexpat.lai /usr/lib/apache/libexpat.la
libtool: install: /usr/bin/install -c .libs/libexpat.a /usr/lib/apache/libexpat.a
libtool: install: chmod 644 /usr/lib/apache/libexpat.a
libtool: install: ranlib /usr/lib/apache/libexpat.a
/usr/lib/apache
during execution
during linking
/usr/bin/install -c -m 644 ./lib/expat.h /usr/include/apache
/bin/sh /usr/local/directadmin/custombuild/httpd-2.4.18/srclib/apr/libtool --mode=install /usr/bin/install -c -m 755 libaprutil-1.la /usr/lib/a pache
libtool: install: warning: relinking `libaprutil-1.la'
libtool: install: (cd /usr/local/directadmin/custombuild/httpd-2.4.18/srclib/apr-util; /bin/sh /usr/local/directadmin/custombuild/httpd-2.4.18/ srclib/apr/libtool --silent --mode=relink gcc -pthread -I/usr/local/include -DHAVE_CONFIG_H -DLINUX -D_REENTRANT -D_GNU_SOURCE -I/usr/local/di rectadmin/custombuild/httpd-2.4.18/srclib/apr-util/include -I/usr/local/directadmin/custombuild/httpd-2.4.18/srclib/apr-util/include/private -I /usr/local/directadmin/custombuild/httpd-2.4.18/srclib/apr/include -I/usr/local/directadmin/custombuild/httpd-2.4.18/srclib/apr-util/xml/expat/ lib -version-info 5:4:5 -L/usr/local/lib -o libaprutil-1.la -rpath /usr/lib/apache buckets/apr_brigade.lo buckets/apr_buckets.lo buckets/apr_bu ckets_alloc.lo buckets/apr_buckets_eos.lo buckets/apr_buckets_file.lo buckets/apr_buckets_flush.lo buckets/apr_buckets_heap.lo buckets/apr_buck ets_mmap.lo buckets/apr_buckets_pipe.lo buckets/apr_buckets_pool.lo buckets/apr_buckets_refcount.lo buckets/apr_buckets_simple.lo buckets/apr_b uckets_socket.lo crypto/apr_crypto.lo crypto/apr_md4.lo crypto/apr_md5.lo crypto/apr_passwd.lo crypto/apr_sha1.lo crypto/crypt_blowfish.lo cryp to/getuuid.lo crypto/uuid.lo dbd/apr_dbd.lo dbm/apr_dbm.lo dbm/apr_dbm_sdbm.lo dbm/sdbm/sdbm.lo dbm/sdbm/sdbm_hash.lo dbm/sdbm/sdbm_lock.lo dbm /sdbm/sdbm_pair.lo encoding/apr_base64.lo hooks/apr_hooks.lo ldap/apr_ldap_stub.lo ldap/apr_ldap_url.lo memcache/apr_memcache.lo misc/apr_date. lo misc/apr_queue.lo misc/apr_reslist.lo misc/apr_rmm.lo misc/apr_thread_pool.lo misc/apu_dso.lo misc/apu_version.lo strmatch/apr_strmatch.lo u ri/apr_uri.lo xlate/xlate.lo xml/apr_xml.lo -lrt -lcrypt -lpthread /usr/local/directadmin/custombuild/httpd-2.4.18/srclib/apr-util/xml/expat/li bexpat.la -liconv /usr/local/directadmin/custombuild/httpd-2.4.18/srclib/apr/libapr-1.la -lrt -lcrypt -lpthread )
libtool: install: /usr/bin/install -c -m 755 .libs/libaprutil-1.so.0.5.4T /usr/lib/apache/libaprutil-1.so.0.5.4
libtool: install: (cd /usr/lib/apache && { ln -s -f libaprutil-1.so.0.5.4 libaprutil-1.so.0 || { rm -f libaprutil-1.so.0 && ln -s libaprutil-1. so.0.5.4 libaprutil-1.so.0; }; })
libtool: install: (cd /usr/lib/apache && { ln -s -f libaprutil-1.so.0.5.4 libaprutil-1.so || { rm -f libaprutil-1.so && ln -s libaprutil-1.so.0 .5.4 libaprutil-1.so; }; })
libtool: install: /usr/bin/install -c -m 755 .libs/libaprutil-1.lai /usr/lib/apache/libaprutil-1.la
libtool: install: /usr/bin/install -c -m 755 .libs/libaprutil-1.a /usr/lib/apache/libaprutil-1.a
libtool: install: chmod 644 /usr/lib/apache/libaprutil-1.a
libtool: install: ranlib /usr/lib/apache/libaprutil-1.a
/usr/lib/apache
during execution
during linking
/usr/bin/install -c -m 644 aprutil.exp /usr/lib/apache
/usr/bin/install -c -m 755 apu-config.out /usr/bin/apu-1-config
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/srclib/apr-util'
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/srclib'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/srclib'
make[1]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/srclib'
Making install in os
make[1]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/os'
Making install in unix
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/os/unix'
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/os/unix'
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/os/unix'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/os/unix'
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/os'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/os'
make[1]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/os'
Making install in server
make[1]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/server'
Making install in mpm
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/server/mpm'
Making install in event
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/server/mpm/event'
make[4]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/server/mpm/event'
/usr/local/directadmin/custombuild/httpd-2.4.18/srclib/apr/libtool --silent --mode=install install mod_mpm_event.la /usr/lib/apache/
make[4]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/server/mpm/event'
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/server/mpm/event'
Making install in prefork
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/server/mpm/prefork'
make[4]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/server/mpm/prefork'
/usr/local/directadmin/custombuild/httpd-2.4.18/srclib/apr/libtool --silent --mode=install install mod_mpm_prefork.la /usr/lib/apache/
make[4]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/server/mpm/prefork'
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/server/mpm/prefork'
Making install in worker
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/server/mpm/worker'
make[4]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/server/mpm/worker'
/usr/local/directadmin/custombuild/httpd-2.4.18/srclib/apr/libtool --silent --mode=install install mod_mpm_worker.la /usr/lib/apache/
make[4]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/server/mpm/worker'
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/server/mpm/worker'
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/server/mpm'
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/server/mpm'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/server/mpm'
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/server'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/server'
make[1]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/server'
Making install in modules
make[1]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules'
Making install in aaa
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/aaa'
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/aaa'
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/aaa'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/aaa'
Making install in cache
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/cache'
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/cache'
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/cache'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/cache'
Making install in core
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/core'
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/core'
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/core'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/core'
Making install in database
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/database'
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/database'
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/database'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/database'
Making install in debugging
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/debugging'
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/debugging'
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/debugging'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/debugging'
Making install in filters
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/filters'
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/filters'
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/filters'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/filters'
Making install in http
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/http'
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/http'
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/http'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/http'
Making install in loggers
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/loggers'
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/loggers'
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/loggers'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/loggers'
Making install in metadata
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/metadata'
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/metadata'
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/metadata'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/metadata'
Making install in proxy
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/proxy'
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/proxy'
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/proxy'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/proxy'
Making install in session
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/session'
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/session'
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/session'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/session'
Making install in slotmem
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/slotmem'
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/slotmem'
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/slotmem'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/slotmem'
Making install in ssl
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/ssl'
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/ssl'
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/ssl'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/ssl'
Making install in proxy/balancers
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/proxy/balancers'
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/proxy/balancers'
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/proxy/balancers'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/proxy/balancers'
Making install in arch/unix
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/arch/unix'
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/arch/unix'
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/arch/unix'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/arch/unix'
Making install in dav/main
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/dav/main'
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/dav/main'
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/dav/main'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/dav/main'
Making install in generators
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/generators'
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/generators'
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/generators'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/generators'
Making install in dav/fs
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/dav/fs'
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/dav/fs'
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/dav/fs'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/dav/fs'
Making install in dav/lock
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/dav/lock'
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/dav/lock'
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/dav/lock'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/dav/lock'
Making install in mappers
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/mappers'
make[3]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/mappers'
make[3]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/mappers'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules/mappers'
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules'
make[1]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/modules'
Making install in support
make[1]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/support'
make[2]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/support'
make[2]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/support'
make[1]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/support'
make[1]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18'
Building shared: mod_mpm_event.la
make[5]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/server/mpm/event'
make[5]: Nothing to be done for `local-shared-build'.
make[5]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/server/mpm/event'
Building shared: mod_mpm_prefork.la
make[5]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/server/mpm/prefork'
make[5]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/server/mpm/prefork'
Building shared: mod_mpm_worker.la
make[5]: Entering directory `/usr/local/directadmin/custombuild/httpd-2.4.18/server/mpm/worker'
make[5]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.18/server/mpm/worker'
cd support && make suexec
make[2]: `suexec' is up to date.
Installing configuration files
[PRESERVING EXISTING HTDOCS SUBDIR: /var/www/htdocs]
[PRESERVING EXISTING ERROR SUBDIR: /var/www/error]
[PRESERVING EXISTING ICONS SUBDIR: /var/www/icons]
[PRESERVING EXISTING CGI SUBDIR: /var/www/cgi-bin]
Installing header files
Installing build system files
Installing man pages and online manual
Restoring certificate and key, and turning on httpd for DirectAdmins's check.
Checking to ensure /etc/httpd/conf/ssl.crt/server.ca is set.
Found /usr/local/directadmin/custombuild/mod_aclr2-1.0.0.tar.gz
Extracting /usr/local/directadmin/custombuild/mod_aclr2-1.0.0.tar.gz...
Installing mod_aclr2-1.0.0...
/var/www/build/libtool --silent --mode=compile gcc -std=gnu99 -prefer-pic -I/usr/local/include -DLINUX -D_REENTRANT -D_GNU_SOURCE -pthread -I/ usr/include/apache -I/usr/include/apache -I/usr/include/apache -c -o mod_aclr2.lo mod_aclr2.c && touch mod_aclr2.slo
/var/www/build/libtool --silent --mode=link gcc -std=gnu99 -L/usr/local/lib -o mod_aclr2.la -rpath /usr/lib/apache -module -avoid-version mod_aclr2.lo
/var/www/build/instdso.sh SH_LIBTOOL='/var/www/build/libtool' mod_aclr2.la /usr/lib/apache
/var/www/build/libtool --mode=install install mod_aclr2.la /usr/lib/apache/
libtool: install: install .libs/mod_aclr2.so /usr/lib/apache/mod_aclr2.so
libtool: install: install .libs/mod_aclr2.lai /usr/lib/apache/mod_aclr2.la
libtool: install: install .libs/mod_aclr2.a /usr/lib/apache/mod_aclr2.a
libtool: install: chmod 644 /usr/lib/apache/mod_aclr2.a
libtool: install: ranlib /usr/lib/apache/mod_aclr2.a
/usr/lib/apache
during execution
during linking
chmod 755 /usr/lib/apache/mod_aclr2.so
[activating module `aclr' in /etc/httpd/conf/httpd.conf]
mod_aclr2 has been installed successfully.
Using <<<MY-server-IP>>> for your server IP
Restarting apache.
Stopping httpd: [ OK ]
Starting httpd:
Found /usr/local/directadmin/custombuild/nginx-1.8.1.tar.gz
Extracting /usr/local/directadmin/custombuild/nginx-1.8.1.tar.gz...
Configuring nginx-1.8.1
checking for OS
+ Linux 2.6.32-573.18.1.el6.x86_64 x86_64
checking for C compiler ... found
+ using GNU C compiler
+ gcc version: 4.4.7 20120313 (Red Hat 4.4.7-16) (GCC)
checking for gcc -pipe switch ... found
checking for gcc builtin atomic operations ... found
checking for C99 variadic macros ... found
checking for gcc variadic macros ... found
checking for unistd.h ... found
checking for inttypes.h ... found
checking for limits.h ... found
checking for sys/filio.h ... not found
checking for sys/param.h ... found
checking for sys/mount.h ... found
checking for sys/statvfs.h ... found
checking for crypt.h ... found
checking for Linux specific features
checking for epoll ... found
checking for EPOLLRDHUP ... found
checking for O_PATH ... not found
checking for sendfile() ... found
checking for sendfile64() ... found
checking for sys/prctl.h ... found
checking for prctl(PR_SET_DUMPABLE) ... found
checking for sched_setaffinity() ... found
checking for crypt_r() ... found
checking for sys/vfs.h ... found
checking for poll() ... found
checking for /dev/poll ... not found
checking for kqueue ... not found
checking for crypt() ... not found
checking for crypt() in libcrypt ... found
checking for F_READAHEAD ... not found
checking for posix_fadvise() ... found
checking for O_DIRECT ... found
checking for F_NOCACHE ... not found
checking for directio() ... not found
checking for statfs() ... found
checking for statvfs() ... found
checking for dlopen() ... not found
checking for dlopen() in libdl ... found
checking for sched_yield() ... found
checking for SO_SETFIB ... not found
checking for SO_ACCEPTFILTER ... not found
checking for TCP_DEFER_ACCEPT ... found
checking for TCP_KEEPIDLE ... found
checking for TCP_FASTOPEN ... not found
checking for TCP_INFO ... found
checking for accept4() ... found
checking for eventfd() ... found
checking for int size ... 4 bytes
checking for long size ... 8 bytes
checking for long long size ... 8 bytes
checking for void * size ... 8 bytes
checking for uint64_t ... found
checking for sig_atomic_t ... found
checking for sig_atomic_t size ... 4 bytes
checking for socklen_t ... found
checking for in_addr_t ... found
checking for in_port_t ... found
checking for rlim_t ... found
checking for uintptr_t ... uintptr_t found
checking for system byte ordering ... little endian
checking for size_t size ... 8 bytes
checking for off_t size ... 8 bytes
checking for time_t size ... 8 bytes
checking for AF_INET6 ... found
checking for setproctitle() ... not found
checking for pread() ... found
checking for pwrite() ... found
checking for sys_nerr ... found
checking for localtime_r() ... found
checking for posix_memalign() ... found
checking for memalign() ... found
checking for mmap(MAP_ANON|MAP_SHARED) ... found
checking for mmap("/dev/zero", MAP_SHARED) ... found
checking for System V shared memory ... found
checking for POSIX semaphores ... not found
checking for POSIX semaphores in libpthread ... found
checking for struct msghdr.msg_control ... found
checking for ioctl(FIONBIO) ... found
checking for struct tm.tm_gmtoff ... found
checking for struct dirent.d_namlen ... not found
checking for struct dirent.d_type ... found
checking for sysconf(_SC_NPROCESSORS_ONLN) ... found
checking for openat(), fstatat() ... found
checking for getaddrinfo() ... found
checking for PCRE library ... found
checking for PCRE JIT support ... found
checking for OpenSSL library ... found
checking for zlib library ... found
creating objs/Makefile
Configuration summary
+ using system PCRE library
+ using system OpenSSL library
+ md5: using OpenSSL library
+ sha1: using OpenSSL library
+ using system zlib library
nginx path prefix: "/usr"
nginx binary file: "/usr/sbin"
nginx configuration prefix: "/etc/nginx"
nginx configuration file: "/etc/nginx/nginx.conf"
nginx pid file: "/var/run/nginx.pid"
nginx error log file: "/var/log/nginx/error_log"
nginx http access log file: "/var/log/nginx/access_log"
nginx http client request body temporary files: "client_body_temp"
nginx http proxy temporary files: "proxy_temp"
nginx http fastcgi temporary files: "fastcgi_temp"
nginx http uwsgi temporary files: "uwsgi_temp"
nginx http scgi temporary files: "scgi_temp"
Done Configuration.
increasing FD_SETSIZE in os/tpf/os.h ..
Trying to make Nginx...
make -f objs/Makefile
make[1]: Entering directory `/usr/local/directadmin/custombuild/nginx-1.8.1'
cc -c -pipe -O -W -Wall -Wpointer-arith -Wno-unused-parameter -Werror -g '-D FD_SETSIZE=32768' -I src/core -I src/event -I src/event/modules - I src/os/unix -I objs \
-o objs/src/core/nginx.o \
src/core/nginx.c
-o objs/src/core/ngx_log.o \
src/core/ngx_log.c
-o objs/src/core/ngx_palloc.o \
src/core/ngx_palloc.c
-o objs/src/core/ngx_array.o \
src/core/ngx_array.c
-o objs/src/core/ngx_list.o \
src/core/ngx_list.c
-o objs/src/core/ngx_hash.o \
src/core/ngx_hash.c
-o objs/src/core/ngx_buf.o \
src/core/ngx_buf.c
-o objs/src/core/ngx_queue.o \
src/core/ngx_queue.c
-o objs/src/core/ngx_output_chain.o \
src/core/ngx_output_chain.c
-o objs/src/core/ngx_string.o \
src/core/ngx_string.c
-o objs/src/core/ngx_parse.o \
src/core/ngx_parse.c
-o objs/src/core/ngx_inet.o \
src/core/ngx_inet.c
-o objs/src/core/ngx_file.o \
src/core/ngx_file.c
-o objs/src/core/ngx_crc32.o \
src/core/ngx_crc32.c
-o objs/src/core/ngx_murmurhash.o \
src/core/ngx_murmurhash.c
-o objs/src/core/ngx_md5.o \
src/core/ngx_md5.c
-o objs/src/core/ngx_rbtree.o \
src/core/ngx_rbtree.c
-o objs/src/core/ngx_radix_tree.o \
src/core/ngx_radix_tree.c
-o objs/src/core/ngx_slab.o \
src/core/ngx_slab.c
-o objs/src/core/ngx_times.o \
src/core/ngx_times.c
-o objs/src/core/ngx_shmtx.o \
src/core/ngx_shmtx.c
-o objs/src/core/ngx_connection.o \
src/core/ngx_connection.c
-o objs/src/core/ngx_cycle.o \
src/core/ngx_cycle.c
-o objs/src/core/ngx_spinlock.o \
src/core/ngx_spinlock.c
-o objs/src/core/ngx_cpuinfo.o \
src/core/ngx_cpuinfo.c
-o objs/src/core/ngx_conf_file.o \
src/core/ngx_conf_file.c
-o objs/src/core/ngx_resolver.o \
src/core/ngx_resolver.c
-o objs/src/core/ngx_open_file_cache.o \
src/core/ngx_open_file_cache.c
-o objs/src/core/ngx_crypt.o \
src/core/ngx_crypt.c
-o objs/src/core/ngx_proxy_protocol.o \
src/core/ngx_proxy_protocol.c
-o objs/src/core/ngx_syslog.o \
src/core/ngx_syslog.c
-o objs/src/event/ngx_event.o \
src/event/ngx_event.c
-o objs/src/event/ngx_event_timer.o \
src/event/ngx_event_timer.c
-o objs/src/event/ngx_event_posted.o \
src/event/ngx_event_posted.c
-o objs/src/event/ngx_event_accept.o \
src/event/ngx_event_accept.c
-o objs/src/event/ngx_event_connect.o \
src/event/ngx_event_connect.c
-o objs/src/event/ngx_event_pipe.o \
src/event/ngx_event_pipe.c
-o objs/src/os/unix/ngx_time.o \
src/os/unix/ngx_time.c
-o objs/src/os/unix/ngx_errno.o \
src/os/unix/ngx_errno.c
-o objs/src/os/unix/ngx_alloc.o \
src/os/unix/ngx_alloc.c
-o objs/src/os/unix/ngx_files.o \
src/os/unix/ngx_files.c
-o objs/src/os/unix/ngx_socket.o \
src/os/unix/ngx_socket.c
-o objs/src/os/unix/ngx_recv.o \
src/os/unix/ngx_recv.c
-o objs/src/os/unix/ngx_readv_chain.o \
src/os/unix/ngx_readv_chain.c
-o objs/src/os/unix/ngx_udp_recv.o \
src/os/unix/ngx_udp_recv.c
-o objs/src/os/unix/ngx_send.o \
src/os/unix/ngx_send.c
-o objs/src/os/unix/ngx_writev_chain.o \
src/os/unix/ngx_writev_chain.c
-o objs/src/os/unix/ngx_channel.o \
src/os/unix/ngx_channel.c
-o objs/src/os/unix/ngx_shmem.o \
src/os/unix/ngx_shmem.c
-o objs/src/os/unix/ngx_process.o \
src/os/unix/ngx_process.c
-o objs/src/os/unix/ngx_daemon.o \
src/os/unix/ngx_daemon.c
-o objs/src/os/unix/ngx_setaffinity.o \
src/os/unix/ngx_setaffinity.c
-o objs/src/os/unix/ngx_setproctitle.o \
src/os/unix/ngx_setproctitle.c
-o objs/src/os/unix/ngx_posix_init.o \
src/os/unix/ngx_posix_init.c
-o objs/src/os/unix/ngx_user.o \
src/os/unix/ngx_user.c
-o objs/src/os/unix/ngx_process_cycle.o \
src/os/unix/ngx_process_cycle.c
-o objs/src/os/unix/ngx_linux_init.o \
src/os/unix/ngx_linux_init.c
-o objs/src/event/modules/ngx_epoll_module.o \
src/event/modules/ngx_epoll_module.c
-o objs/src/os/unix/ngx_linux_sendfile_chain.o \
src/os/unix/ngx_linux_sendfile_chain.c
-o objs/src/event/ngx_event_openssl.o \
src/event/ngx_event_openssl.c
-o objs/src/event/ngx_event_openssl_stapling.o \
src/event/ngx_event_openssl_stapling.c
-o objs/src/core/ngx_regex.o \
src/core/ngx_regex.c
cc -c -pipe -O -W -Wall -Wpointer-arith -Wno-unused-parameter -Werror -g '-D FD_SETSIZE=32768' -I src/core -I src/event -I src/event/modules - I src/os/unix -I objs -I src/http -I src/http/modules \
-o objs/src/http/ngx_http.o \
src/http/ngx_http.c
-o objs/src/http/ngx_http_core_module.o \
src/http/ngx_http_core_module.c
-o objs/src/http/ngx_http_special_response.o \
src/http/ngx_http_special_response.c
-o objs/src/http/ngx_http_request.o \
src/http/ngx_http_request.c
-o objs/src/http/ngx_http_parse.o \
src/http/ngx_http_parse.c
-o objs/src/http/ngx_http_header_filter_module.o \
src/http/ngx_http_header_filter_module.c
-o objs/src/http/ngx_http_write_filter_module.o \
src/http/ngx_http_write_filter_module.c
-o objs/src/http/ngx_http_copy_filter_module.o \
src/http/ngx_http_copy_filter_module.c
-o objs/src/http/modules/ngx_http_log_module.o \
src/http/modules/ngx_http_log_module.c
-o objs/src/http/ngx_http_request_body.o \
src/http/ngx_http_request_body.c
-o objs/src/http/ngx_http_variables.o \
src/http/ngx_http_variables.c
-o objs/src/http/ngx_http_script.o \
src/http/ngx_http_script.c
-o objs/src/http/ngx_http_upstream.o \
src/http/ngx_http_upstream.c
-o objs/src/http/ngx_http_upstream_round_robin.o \
src/http/ngx_http_upstream_round_robin.c
-o objs/src/http/ngx_http_parse_time.o \
src/http/ngx_http_parse_time.c
-o objs/src/http/modules/ngx_http_static_module.o \
src/http/modules/ngx_http_static_module.c
-o objs/src/http/modules/ngx_http_index_module.o \
src/http/modules/ngx_http_index_module.c
-o objs/src/http/modules/ngx_http_chunked_filter_module.o \
src/http/modules/ngx_http_chunked_filter_module.c
-o objs/src/http/modules/ngx_http_range_filter_module.o \
src/http/modules/ngx_http_range_filter_module.c
-o objs/src/http/modules/ngx_http_headers_filter_module.o \
src/http/modules/ngx_http_headers_filter_module.c
-o objs/src/http/modules/ngx_http_not_modified_filter_module.o \
src/http/modules/ngx_http_not_modified_filter_module.c
-o objs/src/http/ngx_http_file_cache.o \
src/http/ngx_http_file_cache.c
-o objs/src/http/modules/ngx_http_gzip_filter_module.o \
src/http/modules/ngx_http_gzip_filter_module.c
-o objs/src/http/ngx_http_postpone_filter_module.o \
src/http/ngx_http_postpone_filter_module.c
-o objs/src/http/modules/ngx_http_ssi_filter_module.o \
src/http/modules/ngx_http_ssi_filter_module.c
-o objs/src/http/modules/ngx_http_charset_filter_module.o \
src/http/modules/ngx_http_charset_filter_module.c
-o objs/src/http/modules/ngx_http_userid_filter_module.o \
src/http/modules/ngx_http_userid_filter_module.c
-o objs/src/http/modules/ngx_http_gzip_static_module.o \
src/http/modules/ngx_http_gzip_static_module.c
-o objs/src/http/modules/ngx_http_dav_module.o \
src/http/modules/ngx_http_dav_module.c
-o objs/src/http/modules/ngx_http_autoindex_module.o \
src/http/modules/ngx_http_autoindex_module.c
-o objs/src/http/modules/ngx_http_auth_basic_module.o \
src/http/modules/ngx_http_auth_basic_module.c
-o objs/src/http/modules/ngx_http_access_module.o \
src/http/modules/ngx_http_access_module.c
-o objs/src/http/modules/ngx_http_limit_conn_module.o \
src/http/modules/ngx_http_limit_conn_module.c
-o objs/src/http/modules/ngx_http_limit_req_module.o \
src/http/modules/ngx_http_limit_req_module.c
-o objs/src/http/modules/ngx_http_realip_module.o \
src/http/modules/ngx_http_realip_module.c
-o objs/src/http/modules/ngx_http_geo_module.o \
src/http/modules/ngx_http_geo_module.c
-o objs/src/http/modules/ngx_http_map_module.o \
src/http/modules/ngx_http_map_module.c
-o objs/src/http/modules/ngx_http_split_clients_module.o \
src/http/modules/ngx_http_split_clients_module.c
-o objs/src/http/modules/ngx_http_referer_module.o \
src/http/modules/ngx_http_referer_module.c
-o objs/src/http/modules/ngx_http_rewrite_module.o \
src/http/modules/ngx_http_rewrite_module.c
-o objs/src/http/modules/ngx_http_ssl_module.o \
src/http/modules/ngx_http_ssl_module.c
-o objs/src/http/modules/ngx_http_proxy_module.o \
src/http/modules/ngx_http_proxy_module.c
-o objs/src/http/modules/ngx_http_fastcgi_module.o \
src/http/modules/ngx_http_fastcgi_module.c
-o objs/src/http/modules/ngx_http_uwsgi_module.o \
src/http/modules/ngx_http_uwsgi_module.c
-o objs/src/http/modules/ngx_http_scgi_module.o \
src/http/modules/ngx_http_scgi_module.c
-o objs/src/http/modules/ngx_http_memcached_module.o \
src/http/modules/ngx_http_memcached_module.c
-o objs/src/http/modules/ngx_http_empty_gif_module.o \
src/http/modules/ngx_http_empty_gif_module.c
-o objs/src/http/modules/ngx_http_browser_module.o \
src/http/modules/ngx_http_browser_module.c
-o objs/src/http/modules/ngx_http_upstream_hash_module.o \
src/http/modules/ngx_http_upstream_hash_module.c
-o objs/src/http/modules/ngx_http_upstream_ip_hash_module.o \
src/http/modules/ngx_http_upstream_ip_hash_module.c
-o objs/src/http/modules/ngx_http_upstream_least_conn_module.o \
src/http/modules/ngx_http_upstream_least_conn_module.c
-o objs/src/http/modules/ngx_http_upstream_keepalive_module.o \
src/http/modules/ngx_http_upstream_keepalive_module.c
-o objs/src/http/modules/ngx_http_stub_status_module.o \
src/http/modules/ngx_http_stub_status_module.c
-o objs/ngx_modules.o \
objs/ngx_modules.c
cc -o objs/nginx \
-lpthread -lcrypt -lpcre -lssl -lcrypto -ldl -lz
make[1]: Leaving directory `/usr/local/directadmin/custombuild/nginx-1.8.1'
make -f objs/Makefile manpage
sed -e "s|%%PREFIX%%|/usr|" \
-e "s|%%PID_PATH%%|/var/run/nginx.pid|" \
-e "s|%%CONF_PATH%%|/etc/nginx/nginx.conf|" \
-e "s|%%ERROR_LOG_PATH%%|/var/log/nginx/error_log|" \
< man/nginx.8 > objs/nginx.8
Make complete
Installing Nginx...
nginx: no process killed
make -f objs/Makefile install
test -d '/usr' || mkdir -p '/usr'
test ! -f '/usr/sbin' || mv '/usr/sbin' '/usr/sbin.old'
cp objs/nginx '/usr/sbin'
test -d '/etc/nginx' || mkdir -p '/etc/nginx'
cp conf/koi-win '/etc/nginx'
cp conf/koi-utf '/etc/nginx'
cp conf/win-utf '/etc/nginx'
test -f '/etc/nginx/mime.types' || cp conf/mime.types '/etc/nginx'
cp conf/mime.types '/etc/nginx/mime.types.default'
test -f '/etc/nginx/fastcgi_params' || cp conf/fastcgi_params '/etc/nginx'
cp conf/fastcgi_params '/etc/nginx/fastcgi_params.default'
test -f '/etc/nginx/fastcgi.conf' || cp conf/fastcgi.conf '/etc/nginx'
cp conf/fastcgi.conf '/etc/nginx/fastcgi.conf.default'
test -f '/etc/nginx/uwsgi_params' || cp conf/uwsgi_params '/etc/nginx'
cp conf/uwsgi_params '/etc/nginx/uwsgi_params.default'
test -f '/etc/nginx/scgi_params' || cp conf/scgi_params '/etc/nginx'
cp conf/scgi_params '/etc/nginx/scgi_params.default'
test -f '/etc/nginx/nginx.conf' || cp conf/nginx.conf '/etc/nginx/nginx.conf'
cp conf/nginx.conf '/etc/nginx/nginx.conf.default'
test -d '/var/run' || mkdir -p '/var/run'
test -d '/var/log/nginx' || mkdir -p '/var/log/nginx'
test -d '/usr/html' || cp -R html '/usr'
grep: /etc/nginx/directadmin-vhosts.conf: No such file or directory
Creating dhparam in /etc/nginx/ssl.crt/dhparams.pem
Generating DH parameters, 2048 bit long safe prime, generator 2
This is going to take a long time
--2016-03-03 13:24:53-- http://files.directadmin.com/services/custombuild/nginx.logrotate
Resolving files.directadmin.com... 216.144.254.90, 69.162.69.58, 208.167.226.3
Connecting to files.directadmin.com|216.144.254.90|:80... connected.
Length: 186 [text/plain]
Saving to: `/etc/logrotate.d/nginx'
100%[=====================================================================================================>] 186 --.-K/s in 0s
2016-03-03 13:24:53 (63.6 MB/s) - `/etc/logrotate.d/nginx' saved [186/186]
Restarting nginx.
Starting nginx: nginx: [emerg] bind() to <<<MY-server-IP>>>:80 failed (98: Address already in use)
nginx: [emerg] bind() to 127.0.0.1:80 failed (98: Address already in use)
nginx: [emerg] still could not bind()
[FAILED]
[root@sr4 custombuild]# ./build rewrite_confs
0
0
Gracefully shutting down php-fpm56: done
Starting php-fpm56: done
/var/www/build/libtool --silent --mode=compile gcc -std=gnu99 -prefer-pic -I/usr/local/include -DLINUX -D_REENTRANT -D_GNU_SOURCE -pthread -I/usr/include/apache -I/usr/include/apache -I/usr/include/apache -c -o mod_aclr2.lo mod_aclr2.c && touch mod_aclr2.slo
/usr/lib/apache
during execution
during linking
Restarting apache.
Starting httpd:
Gracefully shutting down php-fpm56: . done
Restarting nginx.
[FAILED]
