problem with rapidSSL
ensimek
Hi guys I've problem with rapidSSL on http://www.komatel.pl, i created CSR and a key on shell, then i copied CSR and ordered rapidSSL, when I received certificate i pasted it with 'use CA cert' and i got message saying that certificate was installed successfully and my website will be secure in few minutes.
As you see at www.komatel.pl certificate is not working because it's not certified by CA, but user config file is pointing to correct cert from Geotrust:
SSLCACertificateFile=/usr/local/directadmin/data/users/komatel/domains/komatel.pl.cacert
Please help ;[
I see no difference between what I did and what I have to do from site-helper except my CSR was generated via shell - but i dont think it's causing the problem..., do you scsi?
The problem is propably DES3. I created key file with -des3 option :/
Can i install this certificate anyway somehow?>
Working already, thanks
