It's entirely possible that I'm overlooking something, but I'm having a an issue with restoring a reseller account and all user accounts under that reseller.
I should mention that I am using a "pre-release" build 1.331 of DirectAdmin but I don't believe any of the changes relate to DNS or the backup/restore system.
The main problem is regarding DNS zone data. I was expecting the DNS zones to essentially be replicated exactly as they were on the old machine (with the exception of course of an IP change). However, after the restore process the DNS zones had a mix of the old records plus most of the default records that you would get if you were adding an account for the first time. This is problematic as I had to go and manually correct all the zones. In some cases even things like the SPF TXT record was overwritten with the default SPF record. Can anyone shed any light on this?
Also, there was some manual correction needed with the IP settings, as I had an IP that was shared among many users but when restored DirectAdmin marked it as owned by a particular user.
I'd go through the process again to see if the same thing would happen but I don't have a lot of time and I'm not sure how I could test the restore on another server without having another DA license.
