Problem with SPF record and NATted DA
AxisNL
Hey,
I've got a first natted DA machine. Works fine most of the time, I linked the internal and the external ip.
Most dns records work fine, but the SPF record still contains the lan address. Is there an option that I can easily change this behaviour?
Angelo.
SPF is a TXT record right ? why cant you change the Local IP with the external IP ?, just remove the old one and make a new one
Hey,
Angelo.
An SPF record is a Sender Policy Framework record. It's used to indicate to mail exchanges which hosts are authorized to send mail for a domain. It's defined in RFC 4408, and clarified by RFC 7208.
