Problem with system backup -- Root partition not shown
killabee
I am having troubles with configuring the system backup on a direct admin server. It is failing because da thinks there is to less space:
Performing sanity checks: Completed
Checking load average: Completed
Checking free disk space: Insufficient amount of free disk space, aborting...
Performing cleanup operations: Completed
I think it is because of to less space on the /var partition. But I don;t want to backup to the /var partition, but to the root (/) partition. That one isn't showd in the systembackup webpage (see attached file). It only shows /boot and /var, but not the root mount point.
I do have enough space on the root partition:
/dev/mapper/VolGroup00-LogVol00
71G 11G 57G 16% /
/dev/sda1 145M 19M 119M 14% /boot
none 506M 0 506M 0% /dev/shm
/dev/sda2 2.0G 935M 935M 51% /var
Could the problem be that the first line contains the device name and the second the mount point info ?
Thanks for your help!
Ray
I use the /var mount point in the system configuraton backup screen. But that is because I don't see the root mount point in the drop down menu.
The /var mount point doesn't have enough disk space and I don't want to backup there. So basicly my question comes to this: How can I use the root partition as my backup partition in my scenario ?
Thanks for your reply!
I received an e-mail from directadmin support:
Try to manually edit /usr/local/sysbk/conf.sysbk
and change the 2 lines to show:
MOUNT_POINT="/"
BACKUP_PATH="/backup"
The reason it's not showing up is because the "df" command is returning the result for / on 2 lines which is confusing the parser. I'll try and fix that for the next release.
Thank you,
DirectAdmin Web Control Panel
http://www.directadmin.com
This worked out fine :D
Thanks for your fast support. I appreciate it.
