Problems with default MX Zone
fabweb
we are migrating part of our cPanel framework to directadmin. We chose to use cPanel DNS Cluster.
Whenever I restore a DirectAdmin backup from cpanel the MX entries do not work.
I tried to edit dns_mx.conf to "host-name.com=10" but it still doesn't work.
Has anyone ever experienced this?
PS: Sorry if I posted in the wrong place.
fabweb
The server creates the MX entry like this:
domain.tld. MX 10 mail
I think the correct would be the example:
domain.tld. MX 10 mail.domain.tld. or
domain.tld. MX 10 hostname.com.
zEitEr
Super Moderator
GMT +7.00
The record is correct in bind9/named syntax
it's the same as
[COLOR=#333333]domain.tld.[/COLOR]
If you use a custom script to sync zones to remote DNS services then you might need to change it to a FQDN.
In this case copy
/usr/local/directadmin/data/templates/dns_mx.conf to /usr/local/directadmin/data/templates/custom/ and update the /usr/local/directadmin/data/templates/custom/dns_mx.conf
mail.|DOMAIN|.=10
It will effect only new domains created on a server. You will need to take additional actions to update existing ones whenever it's required.
fabweb
it's the same as
In this case copy
mail.|DOMAIN|.=10
Thank you. I will try this now.
