PROBLEMS WITH DNS MANAGEMENT
Maca
Hi I'm an enthusiastic, meaning that I'm far from being a developer.
Having said my disclaimer, I need to change some records on my DNS so that I can set up properly my emails.
However I cannot access to my "DNS MANAGEMENT" on my Directadmin control panel.
I've have made a login key and allowed it to do everything, I have logged using my username and the new key.
Never the less when I click on "DNS MANAGEMENT" I see the url changes to /dns and the screen goes to loading mode, all white with the pale blue logo but I get sent back to the page where I was before clicking.
I will be very grateful for your help,
It might be your host is using a 3rd party or other skin or dos not have DNS management enabled for your account.
You don't need login keys for yourself normally.
Otherwise try using the Enhanced skin (if you can chance skin) and see if it works from there.
And you can also try if things look otherwise when using another browser.
no idea on how to enchamce a skin ?
I ve tried safari and chrome before post neither work .
