Rspamd not running
SeLLeRoNe
Super Moderator
A Coruña, Spain
I absolutely agree that it's better to use the OS provided ones, unless for some reason a newer version is required and available in CB.
Regarding the "use Rspamd RPM" I don't agree to much, I prefer software compiled on the box as for all the software (or almost all) in CB, otherwise why not simply do the same for Apache, Nginx and so on.
The ability to build from source will always allow to enable/add feature that the RPM don't come immediatly with.
As, for example, in exim not using the pre-compiled package allow me to enable experimental features as Generate DMARC Report which wouldn't be available otherwise.
If you have a test box I would still suggest to run a test doing the symlink.
I did some test on CentOS and it is working fine, of course I used a testdomain so I don't receive spam at all, that's why I am seriously considering to install it on a Production Server for a proper test, also keeping in mind that Rspamd can read Spamassassin configurations and rules, which make very easy to switch over without losing rules that I (or my customers) configured.
The only bit I am a little concerned about (but I need to do some reading about this) is the "Learning" as I use a lot sa-learn to make Spamassassin understand, on a per-email account basis, what each single user consider Spam and what Ham and I don't know if also that is "ported" into Rspamd and how to work with it in Rspamd to to the same based on Inbox and Spam folders.
tristan
The Netherlands
Completely agree on this point as well. I gave John access to this test box so he'll probably have a look himself as well today.
SeLLeRoNe
Super Moderator
A Coruña, Spain
To be honest, I still prefer build the software, also because that way you will be able to always get latest release instead of waiting for Debian guys (or CentOS or whatever) to prepare and release the package for the latest version which usually take some time and it might have some new feature (or fix) that you want/need ASAP. :)
Best regards
tristan
The Netherlands
Didn't make this clear but they're now using the deb directly from the RSpamd repository as documented on:
https://rspamd.com/downloads.html
So they're not using the official Debian repos so no waiting on the non-active maintainer of this package on there fortunately. I don't know whether they also switched to rpm for CentOS though.
SeLLeRoNe
Super Moderator
A Coruña, Spain
Sorry, it's Monday and I didn't notice there was a second page so I replied to something very old xD
Good thing tho that their own packages are being used, I will check if he is gonna do the same for CentOS :)
Cheers
