SSL Problem
Kevin Jaspers
Hello Everybody,
I've seen that i can use the function SNI to use multiple SSL's on one ip.
When i set this enabled i get the massage.
Cannot Execute Your Request
Details
You can only add a certificate if you own the ip you are using
Info for Admins: Assigning an owned IP
I have set reseller SSL to enabled als as the user.
I've search alot and tryed alot but not seems to work.
Does someone have an surgetion?
Already thanks.
Thanks for reacting zEitEr.
I have enabled SNI Support in DA.
With: enable_ssl_sni=1
I've restart DA and Apache and its not working still get the massage.
Some idea?
Already thanks.
