SSL Site Problem
tamino
Hello
I have my SSL certificate working fine , but suddenly about 1 month ago when you access a secure part of the site i get the pop up warning that says.
" The name on the security certificate is invalid or does not match name on site "
But when you view certificate it has site name.
the certificate is "StarterSSL"
Your ideas needed.
Thank You
Providing a link to this would help some.
Remember www is specific to your certificate. In other words, if your cert was with www and your not putting the www in there, you'll get the warning.
Has the cert expired?
tamino, you may think you've got a sig, but none is showing up in your posts.
I think your problem is because your images are loading with the www. whereas your certificate does not contain them. It doesn't look like the page itself has a problem but for each image with a www, firefox generates a notice because those are not covered by the certificate.
