ProWebUK Verified User Joined Jun 9, 2003 Messages 1,447 Location UK Mar 2, 2004 #21 $sock->connect('https://ipnumber',2222); Since you're connecting through https:// i assume you have directadmin set to run under ssl?
M Marckus_e Verified User Joined Feb 18, 2004 Messages 36 Location Sweden Mar 2, 2004 #22 Yes, it is ssl. i have tried with ssl:// https:// and nothing before the ipnumber/hostname in the script and they give me the same error /Marcus
M Marckus_e Verified User Joined Feb 18, 2004 Messages 36 Location Sweden Mar 3, 2004 #23 Problem solved! What solved the problem i don't know. It works just fine now! Thanks for the patient with me! /Best regards Marcus
L l0rdphi1 Verified User Joined Jun 22, 2003 Messages 979 Mar 3, 2004 #24 By the way, how did you get OpenSSL to compile into PHP? What operating system are you running? I was/am having a hell of a time trying to get it working under RH9.
