my server is currently running fine now, load shows "0.03, 0.05, 0.06". CPU "99.6" idle.
with this low loading, how come i'm still using 23324k (about 20M) SWAP memory?you may think it's fine, since it's only 20M SWAP memory used, but i'm actually facing some problem about it.
In the past one week, my server need to be rebooted every 2 days due to too much SWAP used, it caused server load too high, and server dies. what i observed is the SWAP memory usage will go up higher and higher after reboot, it can go up to 300M, i don't have heavy websites on the server, it hosts only about 10 unbusy domains/websites, the server is a celeron 2.4, 512RAM, it should be able to handle it easily.
i'm still trying to solve this problem, attached is the top result i saved when my server died last time.
what could be the reason caused this?
thanks...
 thanks...
