system backup log says remote transfer is completed but not true
psalm91
Always the system backup last log says all transfering files have successfully completed
but I can't find any file in remote server
bdacus01
Murfreesboro
How to define port in there ? in scp ? I have changed ssh port
I dont use sysbk. The original author stopped https://www.rfxn.com/ supporting it. You might have to ask for support or wait for someone else.
If you are looking for Data backup use Admin Backup. I use Restic with it and back up to AWS.
if you want system file backup eg /etc /var
I would write your own. I think there are a few examples on the forums.
psalm91
OH I See , I use all sort of backups already. The only thing that I am stuck now is remote transfer of system files , Just in case I might need them but can't make it :)
floyd
But you don't really need to backup system files. If you are at the point where you need system files then your server already has to be rebuilt. Really all you need is the user backups.
