Warning: The system load average is 22.28
Thank you. Since this is live server will be also possible to download all machine configuration and do a test in local enviroment?
I think the upgrading part of MariaDB won't be such an issue, but you can download websites and run a local webserver like MAMP or WAMP to test your websites if they still work with the higher version of MariaDB
Hello i got another alert load average. Is this a bruteforce or Ddos attack?
might just be a higher load than the server can handle, or heavy unindexed queries being frequently ran
Higher load like that can also happen for many reasons, if you have run out of ram from too much load and your using swap. Or if linux kernel swappiness setting needs to be adjusted. Can also be caused by sql server configuration needing to be optimized to be better handle it's load.
Okay i think to have low security on server..
If i click on "maximize" attached security option will be enabled?
Any risk of issue with websites?
