chmodd and making a directory
hellsgate2007
hello,
i cant make a directory or i cant chmod any file in direct admin i get
An error occurred while attempting to create the directory
Details
Parent directory does not allow write, or one of the directories didn't allow search (execution) permission
or
Unable to set file permissions
Details
Unable to chmod /domains/sahat-mawsil.net/public_html/components/com_remository/images to 777
what must i do?
hello,
Details
or
Details
what must i do?
Same my broblem, i can't delete, edit, any file or folder, with details
Unable to delete directory /domains/tinhyeugioitinh.info/public_html/checker. The directory /domains/tinhyeugioitinh.info/public_html/checker is not empty
Set permission levels but cannot work .
Somebody pls help me. thanks .
Who owns the directory?
Mr Jeff can give us more details, i never use Cpanel DirectAdmin before . thank you.
You can't delete an empty directory; you've got to empty the directory first.
If you're sure there's nothing in the directory you want to keep use rm -Rf directoryname instead of rmdir directoryname.
Do you have SELinux turned on? It's not compatible with a hosting server; turn it off.
