You enetered 'xxxxxx'. Ensure this is correct before continuing.
Proceed? (y/n): y
User already exists. Please select a different username.
/usr/local/bin/els: line 3562: wheeluser: command not found
/usr/local/bin/els: line 3564: adduser: command not found
Please enter a password.
Changing password for user xxxxxxx.
New UNIX password:
Retype new UNIX password:
passwd: all authentication tokens updated successfully.
Operation failed.
SSH still allowing root login.
using els --wheeluser doesn't appear to work on my Centos 5 server.
specifically the error appears to be
When the error first occurred, I was SU'd in so I thought it was because els cannot find /usr/sbin/adduser since SU does not appear to override the linux equivalent of the DOS "path" environment variable setting for my login with root's "path".
So I tried again logging in as root and the problem still exists even after I userdel -r xxxxxx, ELS still reports the user xxxxxx as "already exists" although userdel again says user xxxxxx does not exist
I also tried a totally new user with pretty much the same result except the "already exists" part.
Btw, just a small cosmetic typo highlighted there "enetered"
Warning: session_write_close() [function.session-write-close]: open(/tmp/sess_b1c9d964f784ef122e2a33aacdc1b089, O_RDWR) failed: Permission denied (13) in /var/www/html/phpMyAdmin-2.10.1-all-languages/index.php on line 44
Warning: session_write_close() [function.session-write-close]: Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/tmp) in /var/www/html/phpMyAdmin-2.10.1-all-languages/index.php on line 44
Warning: Cannot modify header information - headers already sent by (output started at /var/www/html/phpMyAdmin-2.10.1-all-languages/index.php:44) in /var/www/html/phpMyAdmin-2.10.1-all-languages/index.php on line 101
After I installed APC, I got this error:
Starting httpd: PHP Warning: Unknown(): Unable to load dynamic library './apc/apc.so' - ./apc/apc.so: cannot open shared object file: No such file or directory in Unknown on line 0
What should I do?
Try Zend Optimizer 3.2.8 and eAccelerator 0.9.5.1.
No, both Zend Optimizer 3.2.8 and eAccelerator 0.9.5.1 are allowed. About "doapache2", it's "daapache2" and fixed in 2.1.0.16.
Do "els --update" again.
P.S. I only have moneybookers, epassporte, e-gold and my bank account. I have one man who can convert PayPal for me, but it's not an easy way to get money too![]()
