All sites could not receive emails yesterday
selfwebhosting
Canada
This morning a customer reported he expected some emails and never received them. I checked indeed I could not receive any test emails sent to some of my email accounts for sites hosted on this dedicated server.
Have tried all things I can think of, eventually I had to cold-reboot the server. Now emails get delivered OK but my customer wants to know if yesterday emails got deleted or stored somewhere.
Don't know what caused this problem to happen. I am bit concerned about clamAV. Could it block all emails it exim.conf was not set up properly?
Having seen this problem, I undo what is suggested here for clamAV:
http://www.directadmin.com/forum/showthread.php?t=12099
that is, comment out av_scanner = clamd:/tmp/clamd and the lines added after check_message:
Did this do the trick or the cold-reboot?
Also don't know if all the emails were gone or stored somewhere on the serve.
I have what seems to be the same problem this morning. The customer said his email to me earlier sent fine. I went to check my mail and sure enough, I could not receive. Office Outlook didn't give me any details on the errors.
I checked my webmail and I did in fact receive his message. It seems like only retrieving email was affected.
I then came here and found this thread.
I restarted the server and email receives fine. It seems more than coincidence that this happened to 2 of us around the same time.
Any ideas?
This just happened to me now... I am not receiving any email into my email accounts even though it does appear to complete in the logs....
What the heck is going on???
Follow-up!!!!
Somehow my exim.conf got changed back to the mbox format and not the Maildir format. I am not sure how that happened...
Anyway it is fixed now... Except Domain Alias Pointers still don't put the email in the proper box.
If I were you I'd sure want to know how your exim.conf file got changed; this should never happen by itself.
At the email level what you call Domain Alias Pointers is a link, in /home/USERNAME/imap/ as follows:
lrwxrwxrwx   1 USERNAME mail       15 Jul 23  2006 alias.example.com -> original.example.com
I know it says imap but it works for POP as well.
Hmmm, when I look there, there is two folders not s sym-link like you said, both folders have usernames in them. Can I remove the alias folder and make a sym-link? If so do you know the command off hand?
You got it!!!!
I needed to delete the existing folder and make a sym link. Wow what a pain!
Thank you JEFF!!!!!!
You also have to wonder how that happened. Is the domain either especiall old (on the server) or brand new? I can't help but be curious; I've never run across this before.
I've removed your other thread as it's become unnecessary and a duplicate.
Domain is old, but..... I messed with it today by changing the original domain to the alias and then the alias to the original. However I think maybe when I converted to Dovecot it didn't update that mailbox for some reason.
I am looking into seeing if anyone else with aliases are not getting email as well. I will update this thread if I find anything new.
