Google apps on DirectAdmin
qqjawe
Hi there, i am have full admin rights of the direct admin.
I had set all the MX Record correctly.
Now this is the part which headache me most cname
http://mail.tofushops.com point to google apps email
Detail below
ftp A 220.232.234.112
localhost A 127.0.0.1
pop A 220.232.234.112
tofushops.com. A 220.232.234.112
www A 220.232.234.112
tofushops.com. NS ns1.momi.wakwakdns.com.
tofushops.com. NS ns2.momi.wakwakdns.com.
ALT1.ASPMX.L.GOOGLE.COM MX 20
ALT2.ASPMX.L.GOOGLE.COM MX 30
ASPMX.L.GOOGLE.COM MX 10
ASPMX2.GOOGLEMAIL.COM MX 40
ASPMX3.GOOGLEMAIL.COM MX 50
googlee5ab1b062bbcdc16.tofushops.com. CNAME google.com.
mail CNAME tofushops.com.
mail.tofushops.com. CNAME ghs.google.com.
tofushops.com. TXT "v=spf1 a mx ip4:220.232.234.112 ?all".
Please help.
As you can see http://mail.tofushops.com is not working... to goggle apps mail
My MX Records
MX records.
Name Type Value Select
Is that correct?
My MX Records
MX records.
Is that correct?
To my knowledge the settings are correct except that there must be a period (.) at the end of each record for example ASPMX.L.GOOGLE.COM. not ASPMX.L.GOOGLE.COM
Google apps propagation will take 24-48hrs. Check after that wether its working or not.
If you have dns config in your domain registrar then use it there so that you won't miss any e-mail even if your server goes down.
Registrar like name.com have that feature.
same problem
Hi guys, i think i kind of newbie, i had the same setup but i don't know where's goes wrong please help, please view
360degree.com.my. A 202.190.197.196
cp A 202.190.197.196
ftp A 202.190.197.196
pop A 202.190.197.196
www A 202.190.197.196
360degree.com.my. NS ns14.ipserverone.com.
360degree.com.my. NS ns15.ipserverone.com.
ALT1.ASPMX.L.GOOGLE.COM. MX 20
ALT2.ASPMX.L.GOOGLE.COM. MX 20
ASPMX.L.GOOGLE.COM. MX 10
ASPMX2.GOOGLEMAIL.COM. MX 30
ASPMX3.GOOGLEMAIL.COM. MX 30
ASPMX4.GOOGLEMAIL.COM. MX 30
ASPMX5.GOOGLEMAIL.COM. MX 30
googlece5de18e4c837589 CNAME google.com
mail CNAME 360degree.com.my.
mail.360degree.com.my. CNAME ghs.google.com.
360degree.com.my. TXT "v=spf1 a mx ip4:202.190.197.196 ip4:202.190.197.196 ~all"
You got the MX values (the MX 20 and MX 30's) wrong, I think.
source:
http://www.google.com/support/a/bin/answer.py?hl=en&answer=61162
1. Login to DirectAdmin.
2. Make sure you are on the User Level.
3. Select the domain you want to edit the MX record for (If you only have one domain on your account, you don't need to do this step).
4. Click on MX Records under the E-Mail Management section.
5. Select any MX Records that are there, and then click delete.
6. Put ASPMX.L.GOOGLE.COM. in the text box, and select 10 in the drop-down box. Click Add.
7. Put ALT1.ASPMX.L.GOOGLE.COM. in the text box, and select 20 in the drop-down box. Click Add.
8. Put ALT2.ASPMX.L.GOOGLE.COM. in the text box, and select 30 in the drop-down box. Click Add.
9. Put ASPMX2.GOOGLEMAIL.COM. in the text box, and select 40 in the drop-down box. Click Add.
10. Put ASPMX3.GOOGLEMAIL.COM. in the text box, and select 50 in the drop-down box. Click Add.
11. Uncheck the box beside Use this server to handle my emails.
If not, change the MX record and uncheck this option.
Then, click Save.
Google Apps MX works, but CNAMES don't
Am I missing any "A" records? (and if so what should it be? )
I have my MX records forwarding to Google Apps, and I can get email, but I can not get to the CNAME sites.
Only Google's default sites work:
http://mail.google.com/a/dubosecreditsolutions.com
http://docs.google.com/a/dubosecreditsolutions.com
http://calendar.google.com/a/dubosecreditsolutions.com
http://sites.google.com/a/dubosecreditsolutions.com
but not:
http://mail.dubosecreditsolutions.com
http://docs.dubosecreditsolutions.com
http://calendar.dubosecreditsolutions.com
http://sites.dubosecreditsolutions.com
Can anyone look at my DNS image here and see what I'm doing wrong?
(It's been about 1 day and nothing...I keep getting a DNS error - page can not be found)
