User to reseller
paulus
I tried to search at the forum and at the sitehelper site, but cant found it.
How do I change a existing user to a reseller, without creating a new user? So just changing his user type?
Thanks :D
check in /usr/local/directadmin/scripts
sandy:/usr/local/directadmin/scripts# ls
addip                         directadmin       frontpage.sh      getInfo.sh     majordomo.sh  phpMyAdmin.sh          set_permissions.sh  sysbk.sh
change_database_username.php  directadmin_cron  fstab.sh          getLicense.sh  mysqld        proftpd.sh             setup.sh            update.sh
change_username.sh            doChecks.sh       ftp_download.php  hostname.sh    mysql.sh      README                 setup.txt           webmail.sh
custom                        exim.sh           ftp_list.php      imapd.sh       mysql.sh.old  redirect.php           spam.sh
customapache.sh               files.sh          ftp_upload.php    install.sh     ncftp.sh      removeip               squirrelmail.sh
custombuild.sh                fix_da_user.sh    getDA.sh          ipswap.sh      packages      rotate_email_usage.sh  startips
Are the scripts I see, I see no script what can be used to change it to a reseller? Or am i looking wrong?
which version of DA are you using? Make sure to update your DA to get the latest version, then you can see script for converting user to reseller
Iam using DA 1.31.1:
Compiled for Debian 3.1
Server Version 1.31.1
Current Available Version 1.311000
Last Updated Sun Nov 11 14:50:14 2007
Updated with the update button in DA itself.
I have no idea about Debian system. I am on CentOS, and there are a script there for converting users from user to reseller. You may want to contact John for help...
I have a reseller (ResellerA) need to change to a user. Under ResellerA, i have a user (UserA) need to promote to reseller and keep all the users in ResellerA. Newly change ResellerA to user will under UserA after promoted to reseller?
Will I lost all configuration for ResellerA? Can ResellerA configuration move to UserA?
