Help!!!!!!
seachen
help!!!!!!!!! what happen to my server?
when i login my DA admin level, i found out that all domain add on "P"
after i login on my server root access, it show the message as the pic i attach.
may i know what is the problem?
Two possible senarios: either your temperature threshold is set very low, or you CPU fan is failing. Since the CPU fan is not working properly, it's getting very hot inside your server and slowing down so it generates less heat to protect itself. Make sure the CPU heatsink is properly seated and is adequately rated for the CPU and clock speed you want to use. Better yet, replace your CPU fan with a new one. What kind of hardware your host is using?
The added "P" shows that your domain is a pointer to the main domain for that user (or an alias). If you've never seen it before then perhaps you or someone else has updated DirectAdmin; older versions didn't have that.
