Longer DA Usernames
keefe007
Would it be possible to allow longer DA usernames? I find I could use this quite frequently.
Keefe
I'm not able to duplicate that error.
I created a 14 character username backup, and tried to restore it with:
max_username_length=10
which failed of course.
I then set:
max_username_length=14
restarted DA, and restored again, and the backup was restored without issue.
Let me know if I'm missing anything.
Which OS are you using?
Are there any special characters being used that may be causing the error.
The max length is 14 because of the name limit with MySQL. Hope this helps.
Which is kinda silly, if you have an username of 14 chars, then you cant have a longer mysql user than, say, 5 chars after the <username>_ as it bombs out (did for me when I did testing)
