arbours
NEW OFFICIAL WEBSITE
The official website for it is now available at : www.nesociety.com/nsim2/
PREREQUISTS:
Report to this specific post for old details :
http://www.directadmin.com/forum/showpost.php?p=125042&postcount=47
QUESTIONS, BUGS AND COMMENTS:
Right here in this post. Don't be shy, I do not bite, so say something, otherwise I'll may think no one has interest in this
My Best Regards,
Steve
PREREQUISTS:
- Apache 1 or 2 / PHP 4 or 5.
- That you do complete backup of your system via DirectAdmin or else before you start to test anything
- That you read the INSTALL_README.txt included.
- 2008-03-08 - Packed a prototype beta (means bugs possible) of version 2.0.0
- 2008-03-22 - Total redesign of Package and Users support (View Roadmap below)
- 2008-03-25 - Final decision on packages.
MULTIPLE CURRENCIES SUPPORT!! : Yep, as much currencies as you want, you simply set your base price for your packages, so by example, you set a month base price of 10 buck, then you can add 100 currencies with a different rate (base price * rate) = your currency price. I will also implement the prefered currency for each members as well.
PRICING: Most webhoster work with term of 30 days, 1 year and 3 years, I will eventually build something more custom even if you can, right now modify a subscription to expire at a later or previous time that it was set originally. But for now, I think this will cover a large percentage of people who need NSIM. I will focus on building the backend and others functionnalities. The Cron Billing System is already based on checking by period of 1 days, so it will be expandable, no worry.
The members list (users) is now taken directly from DirectAdmin. What happen is that you simply attach a external profile (stored in NSIM database) where you can attach different extra information, such as billing informations, and possibly in the future more like tickets and transcripts of something
COMPLETED: The packages sections is now completed, and it is NOT taking any plans or package from DirectAdmin. Back to NSIMv1 minding, we allow you to create any number of virtual package template, and at the time of member creation (or ultimatly on your front-end website), you will loop through these virtual package template. Since the API support to create custom account with all the parameters, this will also enable member account to be customized depending on your need. The difference is that you will be able to also enter a BASE PRICE for monthly, yearly and 3 years. Also you will be able to enter a english and/or french title for each virtual packages. Hence that I do call em Virtual Package because we only use em as template to create custom account, but we may reference it as "Packages" only.
I will try to release a new beta (2.0.1) on 2008-03-26 including these update, stay tuned.
- Warning of subscription that will expire (for employees and the targetted members/users)
- Small web template on how to implement NSIM on your current website frontend
When you create an NSIM members/subscription, an invoice can automaticly be sent. My goal is that at this point, if you dont check that this invoice is already paid, the member get his account created but it is suspended. At this point, he shouldn't be able to use it until he pay the invoice that would be sent onto his email address or that is accessible from the members history page on the NSIM customer billing section. So the only thing that is needed is to bridge that subscriptions creation which Ive already build a little set of functions and libraries to acheive so
My Best Regards,
Steve
