jim.thornton
- Jan 1, 2008
I just installed eAccelerator via update.script. The installation seemed to go fine, however, once I add the lines to my php.ini file it is giving me an error 500.
That is the first 20 lines (or so) of my php.ini file. I've inserted the eaccelerator line after the zend optimizer... Is that right?
anyone know why I'm getting this error?
[PHP]
zend_extension=/usr/local/lib/ioncube/ioncube_loader_lin_5.2.so
zend_extension=/usr/local/lib/Zend/ZendOptimizer.so
[Zend Optimizer]
zend_optimizer.optimization_level=15
[eAccelerator]
;zend_extension="/usr/local/lib/php/extensions/no-debug-non-zts-20060613/eaccelerator.so"
;eaccelerator.shm_size="32"
;eaccelerator.cache_dir="/tmp/eaccelerator"
;eaccelerator.enable="1"
;eaccelerator.optimizer="1"
;eaccelerator.check_mtime="1"
;eaccelerator.debug="0"
;eaccelerator.filter=""
;eaccelerator.shm_max="0"
;eaccelerator.shm_ttl="0"
;eaccelerator.shm_prune_period="0"
;eaccelerator.shm_only="0"
;eaccelerator.compress="1"
;eaccelerator.compress_level="9"
