donkeyKICK
- Jul 24, 2007
I am using pop all the way around, but the BB wouldn't go on pop until a call was made to them to force it. It will use IMAP until that is done. The settings on the BB itself wouldn't force IMAP.
Going to dovecot and forcing pop did it me me.
The only other time I was having trouble with duplicate email was not BB related (I was using a VM and the timekeeping was way off, to I set a cron to reset frequently. When the time was set back, Outlook would grab duplicates).
Do you get duplicates in Outlook if you check your email with Squirrelmail?
