x cache
Boten
hello all
please help to install and configure x cache.
Thank you all
Try to follow steps here -> http://www.cyberciti.biz/faq/howto-rhel-install-xcahce-php-opcode-cacher/
However, I did a few change. I don't have xcache.ini. I just merge everything in xcache.ini into php.ini.
About xcache.so, after make install, the file went to different path from that document. So, you have to check where it goes.
Check to make sure xCache loaded before Zend Optimizer or you will get an error that it doesn't work something like that. (Put [xcache-common] before Zend Optimizer.
Also, if you compiled DA in PHP-cgi, just forget this module or anything similar, it doesn't work well with suPHP. When you check, it will say it's installed but it helps nothing.
Update : I just wrote something that is specifically for DA here -> http://www.bxtra.net/Articles/2008-...he-CentOS-52-64-bit-has-DirectAdmin-installed
Thanks my friend xcache is the best !
Thanks nmb for posting the link.
How about custombuild? does it break my config while updating DA the next time?
EDIT: I don't use SuPHP (have a standard DA setup)
