floyd
- Mar 29, 2005
the pulldown list, so I choose "/usr/local/directadmin/data/templates/edit_files.txt" and hit "Show File".
Ah ha. That's the point I was missing. I thought you were editing edit_files.txt from a ssh shell. I thought you were editing the file from a ssh shell so that you could then add sshd_config and then use DA to edit sshd_config which didn't make any sense to me because if you can edit edit_files.txt from the shell you can edit sshd_config from the shell.
I didn't know you could edit edit_files.txt from within DA. I rarely ever use it. Looking at your first post I can see it now. I hope you can see why I was confused. I need to be taught like a 4 year old.
I think it would be a good idea for you to write a HOWTO for this so that other FreeBSD users that make this mistake can overcome it without being physically at the machine. I personally like a numbered step by step HOWTO.
