in case anyone follows me...
I ithnk you all missed the point there were no backups just the crashed disk and a new install of da
it took a few hours but I rescued the server and lost no data, at the same time sneaked in a upgrade from old da apache 1.3 to new custombuild
I copied all the files you see in the system backup
going through very carefully
this got me all the mysql files, users, the home files
but this left me with dovecot not working (cause its new) and apache not working
- I went through the custom httpd files and removed the port and change the user etc to the new syntax
(I created a new account with an email - so I knew what things should look like!)
- I then used the da faq's to convert to dovecot and update all the email passwords to carry a uid
basically if you are in the disaster I was...
- get most of the old files across and whats still not working read the da faq's
which are really quite helpful!
- also set up a test user, so you will have one working - this really helped when I was missing the custom httpd files - they are not included in httpd.conf any more but in the extras folder
(Oh i forgot to say leave the NEW httpd.conf!)
Anyway if you find yourselves in a similar position with loads of users crying, no time and stressed - I am around I'll try and help!
good luck
m
