subdomain email and pop3 problems (newbie)
DirectAdmin does support subdomain email.
DNS doesn't work for ann.abc.com:
 dig ann.abc.com
; <<>> DiG 9.3.1 <<>> ann.abc.com
;; global options:  printcmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 14923
Fix your DNS.
If for some reason you've lied to us about your domain name and subdomain name, please tell us the truth. Otherwise you're wasting our time and yours.
 dig ann.abc.com
;; Got answer:
Fix your DNS.
Sorry, ann.abc.com for example only, the real domain name is ann.bilebala.com, thank !
To Lasman,
What do you think this sub-domain of the email setup ?
I also sent an email to DA support on last Monday till no response.
THX !!
As he mentioned we need to know the e-mail address and the domain name (CORRECT INFO) in order to help you.
R1Lover:
We do now have correct information.
liew:
It seems to work for me; here's a snippet from the smtp connection dialogue:
[jlasman@of1 ~]$ telnet bilebala.com 25
Trying 202.123.66.151...
Connected to bilebala.com (202.123.66.151).
Escape character is '^]'.
220 ih-a22.pointdnshere.com ESMTP Exim 4.67 Sun, 02 Aug 2009 08:48:10 +0800
mail from:<[email protected]>
250 OK
rcpt to:<[email protected]>
250 Accepted
250 Accepted
quit
221 ih-a22.pointdnshere.com closing connection
However pointdnshere.com is a funny name for a server :).
Since your server reports that it's accepted the mail for the john mailbox at ann.bilebala.com, you should check your exim mainlog to see where it's sending it.
R1Lover:
liew:
250 OK
250 Accepted
250 Accepted
quit
I checked the mail log, it sent to [email protected] not [email protected] .....
I tried to use mail command to send email to [email protected], it work find, the following is the log:
2009-08-03 15:01:04 1MXrXc-0007XQ-38 <= [email protected] U=root P=local S=391 T="fdgnuksdf" from <[email protected]> for [email protected]
2009-08-03 15:01:04 1MXrXc-0007XQ-38 => john <[email protected]> F=<[email protected]> R=virtual_user T=virtual_localdelivery S=517
2009-08-03 15:01:04 1MXrXc-0007XQ-38 Completed
The following log is yahoo send to [email protected], you can see the email delivery to [email protected],
2009-08-03 15:02:47 1MXrZG-0007Xy-Nw <= [email protected] H=web54405.mail.yahoo.com [206.190.49.135] P=smtp S=2713 [email protected] T="haha" from <[email protected]> for [email protected]
2009-08-03 15:02:47 1MXrZG-0007Xy-Nw => john <[email protected]> F=<[email protected]> R=virtual_user T=virtual_localdelivery S=2827
2009-08-03 15:02:47 1MXrZG-0007Xy-Nw Completed
THANK !!!!
Double check your e-mail address that you are typing in... if it still does the same try from google or another e-mail service.
p.s. yahoo mail is crap anyway... but it should still work.
There isn't much we can do for you on this since we don't have access to your server, if this still happens send in a support ticket or contact your host if you are not the host.
Hello
Are you sure DA support sub-domain email ?
THANK !
Well if you look at the other post in this thread, you were told to add the sundomain as a new domain rather then under the main domain name. If this was done then it should work just fine.
Sorry, I don't understand ... could you give me a as tep by step example ?
THANK !!!!!!
Also here's the godaddy DNS record, please find attached file.
THANK !!!!!
Sub-domain create page, but it shown
Cannot create that domain
Details
That domain already exists
Please find attached file.
THANK !!!!!
ok, I can create ann.bilebala.com in Domain Administration, but yahoo message said:
Hi. This is the qmail-send program at yahoo.com.
I'm afraid I wasn't able to deliver your message to the following addresses.
This is a permanent error; I've given up. Sorry it didn't work out.
<[email protected]>:
202.123.66.151 does not like recipient.
Remote host said: 550 "Unknown User"
Giving up on 202.123.66.151.
:D:D:D:D:D:D:D
