requires the ionCube PHP Loader ioncube_loader_lin_5.2.so Help needed
SwitchMIA VPS
I just can't get it to work, I switch to all php's from 4 to 5 cgi to cli. any help will be great
Error: requires the ionCube PHP Loader ioncube_loader_lin_5.2.so to be installed by the site administrator.
[root@main ~]# php -v
PHP 5.2.12 (cli) (built: Feb 10 2010 15:19:17)
Copyright (c) 1997-2009 The PHP Group
Zend Engine v2.2.0, Copyright (c) 1998-2009 Zend Technologies
[Zend]
zend_extension=/usr/local/ioncube/ioncube_loader_lin_5.2.so
zend_extension_manager.optimizer=/usr/local/Zend/lib/Optimizer-3.3.3
zend_extension_manager.optimizer_ts=/usr/local/Zend/lib/Optimizer_TS-3.3.3
zend_optimizer.version=3.3.3
zend_extension=/usr/local/Zend/lib/ZendExtensionManager.so
zend_extension_ts=/usr/local/Zend/lib/ZendExtensionManager_TS.so
That doesnt show that its loaded at all. Are you sure your editing the correct php.ini file.
If it is indeed loaded the output of php -v will say "Zend Optimizer Loaded"
Example like my server:
with Zend Extension Manager v1.2.2, Copyright (c) 2003-2007, by Zend Technologies
with Zend Optimizer v3.3.3, Copyright (c) 1998-2007, by Zend Technologies
i was thinking the same, but i edit both /usr/local/Zend/etc/php.ini and the main
You can find your current config file with the following command:
php -i | grep php.ini
this should give you the following output:
Configuration File (php.ini) Path => /usr/local/etc/php5/cgi
Loaded Configuration File => /usr/local/etc/php5/cgi/php.ini
your correct..
but i don't see zend..
# php -i | grep php.ini
php.ini ends
soap.wsdl_cache_ttl=86400
; Local Variables:
; tab-width: 4
; End:
On one of my non DA servers there are 2 php.ini files, you need to edit the cli version also. Not sure if thats your case also.
On Debian in my case it was located in : /etc/php5/cli/php.ini
i added : zend_extension = /usr/local/ioncube/ioncube_loader_lin_5.2.so
i swap the php5 to cli
this is the error i now get
Failed loading /usr/local/ioncube/ioncube_loader_lin_5.2.so: /usr/local/ioncube/ioncube_loader_lin_5.2.so: cannot open shared object file: No such file or directory
Configuration File (php.ini) Path => /usr/local/lib
Loaded Configuration File => /usr/local/Zend/etc/php.ini
# php -v
PHP 5.2.12 (cli) (built: Feb 12 2010 12:37:26)
cd /usr/local
wget -O ioncube_loaders_lin_x86.tar.gz http://downloads2.ioncube.com/loader_downloads/ioncube_loaders_lin_x86.tar.gz
tar xzf ioncube_loaders_lin_x86.tar.gz
rm -f ioncube_loaders_lin_x86.tar.gz
cd /usr/local
yup, that did it.. your the man, thank you so much.
