mysql @ directadmin and a new webhost
djtamse.eu
hello guys sorry if this is an double post, ....
but i have a serious quiston i want to know about,
i want to buy directadmin next month, but what if i want to use ssl... ??
how do i use ssl with direct admin i know how to make the key, but evry good
guide on google seems not to work for me....
second , i have atm mysql php etc phpmyadmin webinterface,
thirdley what i experinced with directadmin where that i was, unable to make
an user called any host the % with the mysql database in directadmin ...
in phpmyadmin it is just 1 click to make localhost or any host ,
what i need to know is if it is even possible to make the any host when i
make a mysql databse with directadmin when i buy it and get it installed
alsp am i able to use ssl on it ... do i need to install ssl before installing
directadmin licens ...?= sorry for my bad english , i come from denmark :)
djtamse.eu dosent exist any more ,how ever i do own a two new domains ...
i will offer some web hosting when the directadmin is installed... i have
100/100 mbit fibernet to share price is 1 euro per user limited traffic limited
disk space etc etc email and so one ;)
guide on google seems not to work for me.... [/quote[
I just did some googling of various DirectAdmin sites, and found:
http://admin.site-helper.com/license.html
http://admin.site-helper.com/rpackages.html
http://reseller.site-helper.com/packages.html
http://www.site-helper.com/ssl.html
http://www.site-helper.com/uploading.html
and a lot more here.
If you ask specific questions we may be able to help you further.
I'm having trouble understanding you. Are you asking about the use of the & character? If so, where?
On DirectAdmin? Of course.
do i need to install ssl before installing directadmin licens ...?
No. directAdmin is installed through ssh, so you need all the libraries, but you do not need a Certificate for the install.
phpmyadmin
hello jeff i attached an image for you to see what my quiston is about, sorry my english m8
greetings from http://freeleech.eu
to any host is something i need to my radio programs i wish to know if i can
do that to in directadmin cause last time i had it i couldent quiet figure out
how to ...
directadmin
i know that, what i want to know if that in direct admin i can have the same
options as in phpadmin as im using now thats what my quieston is about if
you read
DirectAdmin and phpmyadmin are two unrelated pieces of software. No, DirectAdmin does not do everything that phpmyadmin does nor is it supposed to. DirectAdmin is not a phpmyadmin replacement. In fact when you install DirectAdmin it also installs phpmyadmin.
i know that but would i be able to make the any host % when i make a databse ? that all i want to know
I don't see why you would not. If you can do it on the old server then you can do it on the new server as long as phpmyadmin is configured the same.
Again, not related to DirectAdmin although DirectAdmin does handle some mysql things but not all. But what DirectAdmin does not do phpmyadmin can do.
I guess the confusion for me is that with your image you showed us that you are able to do it. So I could not really understand your question. You asked if you could do something that you were already doing. If you are doing then obviously you can do it. Your image answered your own question.
Are you asking "Can I configure my MySQL users to allow connections from other servers", then yes you can...... If I didn't understand the question, ignore me
yes that what i wanted to know m8 and how do i do that ? cause the last time
i had direct admin i couldent find out how to do it...
thanks for the reply m8
DirectAdmin doesn't get in the way of you setting up your MySQL database for access from multiple hosts, but it doesn't help you either. For that you use PHPMyAdmin.
helo jeff the reason why i require to use the any host in the databse i need
to make is cause the program i use need to use the any host from mysql
database that why i need to know if mysql in directadmin can handle that
Again its not related to DirectAdmin. This a mysql question. And yes you can do that with mysql. If you don't know how to do it via command line then you can use phpmyadmin as you have already shown us in your image. DirectAdmin can do some mysql stuff but not everything. But it will not hinder you from doing it with phpmyadmin. You have already show us you know how to do it with phpmyadmin. So what is your question now?
helo jeff the reason why i require to use the any host in the databse i need to make is cause the program i use need to use the any host from mysql
You already know how to do that. You showed us the image. Are you confusing phpmyadmin with DirectAdmin? They are both just software running on the server. DirectAdmin can help you configure mysql and whatever DirectAdmin cannot do you can use phpmyadmin to do.
DirectAdmin is not THE server. It is just some software running on a Linux server much like everything else.
FWIW...... You just go to Domain » MySQL Management » Click a database name then you'll see its user, then the Access Hosts will show on that page. I think you can add a % for a host but its a security risk IMO
i know but just an issue cause the program i need to have % with is needet it wont run buy localhost for some strange reason thanks for the help guys
