gwydion800
- Aug 31, 2010
When looking in server stats it says "Current usage" and "Allocated", but what happend when current usage hits the allocated amount? is there any way to set that number higher?
Maybe the admin account isnt set to unlimited? i.e at CMD_MODIFY_USER?user=admin
Go to show all users
Admin
Modify user and check there
admin root 238.9 / unlimited 78.1 / unlimited 1 / unlimited
I do not think you have not clicked the "Modify User admin" button yet,
I DID look in attach.
Sounds like a VPS to me, if it was a dedi, then the company would (normally) only deploy the server using their (raw) OS distro image for you to install software yourself, as its unmanaged........it's hosted on a dedicated server and the company installed it for me
cd /usr/local/directadmin
echo "action=tally&value=all" >> data/task.queue
./dataskq d200
cd /usr/local/directadmin/data/users
grep bandwidth */user.conf
