unified_ftp_password_file is not set to 1
zEitEr
Super Moderator
www.poralix.com
Trying to install Pure-FTPd, I've got errors:
unified_ftp_password_file is not set to 1. You must convert before you can use pureftpd
Please read this guide: http://www.directadmin.com/features.php?id=1134
Simulation:
cd /usr/local/directadmin
echo 'action=convert&value=unifiedftp&simulate=yes' >> data/task.queue
./dataskq d1
Conversion:
echo 'unified_ftp_password_file=1' >> conf/directadmin.conf
echo 'action=convert&value=unifiedftp' >> data/task.queue
./dataskq d1
Already done these instructions, the error still occurs.
Do I miss something? Is it absolute necessary to use per-release binary from user area? Or can I skip it?
I've done it several times, that didn't help me.
I'm still using Installed version of DirectAdmin: 1.36.2
/usr/local/directadmin/directadmin c | grep unified_ftp_password_file
shows nothing. Should I use pre-release binary?
I've modified temporary custombuild to get ability to install Pure-FTPd.
I've done it. Pure-FTPd is now installed and running.
Where can I found config file for it? Does it still use /etc/proftpd.*?
Thanks for your reply.
Will you, please, help me with answers on other questions?
In the /etc/init.d/pure-ftpd there're two mentions:
/etc/pure-ftpd.conf
/etc/sysconfig/pure-ftpd
but they both don't exist in my Linux. Are they supposed to be used? Should they be created on ./build pureftpd command? Though I've not found any line in build script, that would create any config for it. Or should we be on ourselves to create configs?
And what about logging? File /var/log/pureftpd.log is still empty, no lines since yesterday.
/etc/init.d/pure-ftpd has the following line:
OPTIONS="-B -A -C 4 -H -k 95 -L 2000:8 -O stats:${LOG} -l puredb:${DB} -p 35000:35999 -u 100 -U 133:022 -w -Y 1 -Z"
Change the options to fit your needs. If you'd like to use pureftpd.conf file - use pure-config.pl and modify /etc/init.d/pure-ftpd to use it.
Log file is located here: /var/log/pureftpd.log
/etc/pure-ftpd.conf
Make sure you have the following file on your system (/etc/init.d/pure-ftpd): http://files.directadmin.com/services/custombuild/pure-ftpd.
Hi
We encounter the following error after eternity DirectAdmin
Simulation:
./dataskq d1
Conversion:
./dataskq d1
[root@server custombuild]#
DirectAdmin did not start well
[root@server custombuild]# service directadmin restart
Stopping DirectAdmin: [FAILED]
Starting DirectAdmin: [FAILED]
